How to better secure habitation door when open (1 Viewer)
Smokaijo
118
146
Guildford, UK
Swift Kontiki 679
My partner & I are newbies and have a fully adapted motorhome for myself with my electric wheelchair
Hi Funsters,
We have a cassette lift so the habitation door staying open and fastened to van is a must however in this increasingly windy weather our present female/male connectors are just not doing it!
Today with the winds being gale force I was almost decapitated lol but hubby grabbed the door in time. The pics are what we have right now.
So would be interested in what other funsters have in place . IMG_2514.jpegIMG_2515.jpeg
1,416
6,844
Earby, Lancashire, UK
Autocruse Select 144
started Oct. 2016
I have the solution for you.
For sale on classified door/flap retention clips.
Smokaijo
Smokaijo
118
146
Guildford, UK
Swift Kontiki 679
There was a thread on here recently ref this as many people gave some tips , have a look in search section
Good luck
Wouldn’t happen to know which key words as habitation door sent me down a rabbit hole 🤣🤣🤣
bigtwin
5,261
9,980
Derby
Concorde
Since 2006
Used on hab door ant gas locker
Smokaijo the above is the solution that you are seeking. Any solution that involves a bungee is a Heath Robinson attempt and will, at some point, end up giving you a fat lip (or damage to your paintwork).
Do it right.
The above retainers are used by top motorhome brands as the means to restrain doors/lockers for a reason; they are durable and capable.
Ian
Oct 12, 2009
10,730
23,780
A Class N+B Arto 69GL
Since 2009
Used on hab door and gas locker
Those are the real answer. Forget bungees they just stretch in a strong wind and bang the door around.
They are what are fitted to 44t trailers: imagine one of those trailer doors catching the wind when driver is unloading - broken bones or even fatal.
We have not drilled for these but have a ratchet strap, not bungee, from hab door to wing mirror mounting.
Jan 16, 2014
1,344
2,485
Surrey
Rapido 854f
Since 2012
One of these with a hole drilled through both parts an an R clip on a piece of string
Jan 29, 2017
686
558
Gloucestershire
Lunar Champ H621
15yrs
The horrible thing about these door restraints is that they let go without any warning ,,, until the door hits you.
We've long used a bit of sailing halyard/paracord in our case tied from the door liner to the passenger door handle.
Totally reliable, never let us down,,and cheaper. The deluxe model (1m longer) also let's us restrain the door at 90 degrees for when it's a bit breezy
Mike
Nanniemate
6,191
43,418
Wales
IH
Just bungee it . Glad he didn't let you get decapitated . Are you sure your life insurance is up to date :wink: :rofl:
Aug 3, 2015
100
117
Shropshire
PVC
3 years campervan, many as a tugger
Can thoroughly recommend the NiksNaks “Hab Strap” as sold by Parrotsol Central on EBay for £16.99 - does the job well without causing any damage. Item no.185978509201. Good luck! (And yes, I’m the seller’s proud Mum but it does work, believe me!)
May 30, 2015
18
10
Hampshire
Coach-built
Since 2013
Hi Funsters,
So would be interested in what other funsters have in place .View attachment 850451View attachment 850452
Bungee cord, one end hooked into door, the other on the rear wheel..works a treat!
