Hookup cable (2 Viewers)
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
Just made up a 10m cable using 2.5mm cable and these -
http://www.thecaravanshop.co.uk/electrical-products/mains-plugs-sockets/mains-coupler/prod_878.html
http://www.thecaravanshop.co.uk/ele...s-plugs-sockets/mains-site-plug/prod_879.html
The electrical connections and the screwed flex retention grips were a dawdle however pushing the cable through the end of the units was very tight. Stretched the holes with a pair of fine nosed pliers and they returned to original shape \ size after the cable was through making a good rainproof fitting.
If presented with a tight hole, lube up :giggler:
- talc powder makes the job easier (y)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Paid for yesterday after I posted the link. arrived this morning
86p per metre for 2.5 arctic is a steal
663
373
Ayr
Newbie
It's pretty cheap but when you can a 25 metre cable for just over £26 including the plugs and delivery, is it worth the bother?
Tim
Techno
Jul 28, 2010
15,475
20,756
May 2010
No the regs BS7671 are not law but they may be cited in a court of law as the definative guide.
Techno
Jul 28, 2010
15,475
20,756
May 2010
It is also bullshit. I've never been on a site that asks to see a PAT test label on a hook up lead :ROFLMAO:
Techno
Jul 28, 2010
15,475
20,756
May 2010
I suppose you found one that asks and checks :whistle:
D
Deleted member 29692
Actually there is no statutory requirement to PAT test anything anywhere ever. There is a requirement to ensure the electrical equipment accessible to the public or employees is kept in a safe condition. It is perfectly acceptable to do that by other means, for example a risk assessment could show that the possibility of damage is so remote that a regular visual check it sufficient.
Terry
11,932
9,092
Lincolnshire
Can't remember ;)
Hi Dave are you going for the longest thread or cable :D-You have loads of links to both cables and leads --Since your hook up plug that you plug into will be 16 amps there is no need or requirement to go for bigger cabling unless you think it will prove the better option ;)Nothing in your van will require anything bigger than 16 amps which is basically what your HU will be at max
terry
scotjimland
2,337
10,147
A Woosh bang
They are saying it is a requirement when it is not.
I may have misunderstood..
you were saying that sites asking to see a PAT test label was bullshit .. yes, I agree
I thought you were saying PA testing hook up leads was bullshit..
sorry..
ShiftZZ
ShiftZZ
21,383
84,583
Dark Side of the Moon
Is this a good price for 100m?
2.5mm 100 Metre Drum 3 Core Blue Arctic Cable
Incl. VAT: £66.29
ShiftZZ
ShiftZZ
21,383
84,583
2.5mm 100 Metre Drum 3 Core Blue Arctic Cable £66.29 Ascending Quantity Descending Quantity (1) £66.29
Defender Coupler 230V 16A (Display Pack) £5.10 Ascending Quantity Descending Quantity (3) £15.30
Defender Plug 230V 16A (Display Pack) £4.74 Ascending Quantity Descending Quantity (3) £14.22
Grand Total Incl. VAT £101.31
Feb 16, 2013
19,736
52,043
uttoxeter
ambulance conversion
50 years
£1 a metre including plugs and sockets, can't be bad(y)
Jim
Ringleader
Jul 19, 2007
36,438
130,979
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Some really cheap cable I have seen is just not soft and flexible enough for motorhome use. The cheap stuff has a mind of its own and kinks, twists and tangles easily. Make sure you've not bought such stuff, you'll curse every time you stow it.
ShiftZZ
ShiftZZ
21,383
84,583
Blue artic cable is designed to withstand severe temperatures whilst remaining flexible down to -40°C.
Key Features
  • Plain annealed flexible copper conductor
  • Low temperature PVC insulation
  • Low temperature PVC sheath
  • Blue
Technical Data
Cable size : 2.5mm²
Stranding : 50 / 0.25mm²
Cores : 3
Core Identification : Blue, Brown & Green / Yellow
Overall diameter : 10.15mm²
Temperature limits : -40°C - +70°C
Standards
300 / 500V grade to BS7919 table 44 and BS6500.
Flame propagation to BS EN 50265.
Feb 16, 2013
19,736
52,043
uttoxeter
50 years
Key Features
  • Blue
Technical Data
Cable size : 2.5mm²
Cores : 3
Standards
Have a look at eBay number 141374227947 , don't know if it's artic but cheaper than your roll and already done, with a free house plug
Sorry didn't see the postage but still in line
Teepee
307
228
Essex
Van conversion
1 year
watched a program called fake Britain, loads of dodgy cable being sold, cheap and not being up to standard it says on labels be very careful where you buy cable from. it can be potentially dangerous. its all brand new looks like the real deal. just be sure to buy from reputable dealer. and no I am not a dealer.
