ShiftZZ
What is the min specification for the hookup cable?
2 plugs no need for a socketa plug a socket and some wire
So if I bought :
100 Metre Coil of 2.5mm 3 core Arctic Yellow Cable - NETARC253CY100 Arctic Cables remain Flexible at low temperatures. it is rated for use down to -40 oC at cold bend testing, and 25 oc for installation and handling,where as regular PVC stiffnes. The Yellow version is used in applications like site equipment , to denote 110 Volts, or for example Portable Traffic Lights. or any other conditions that require cold temperature electrical cables. The 2.5mm Stranded Conductor is rated at a maximum of 25 Amps
http://www.edwardes.co.uk/en/search/q/Arctic_Cables
And some sockets, etc...(any specifications re sockets?)
I could get say 1x 50m, 1x25m and 1x 10m and 1 x 15m ?
Not having looked inside the sockets are they a pain to wire up?
pushing the cable through the end of the units was very tight. Stretched the holes with a pair of fine nosed pliers and they returned to original shape \ size after the cable was through making a good rainproof fitting.
The wife was "talking" to me at the time so didn't need the hairdryer!I warmed the plastic with a hairdryer and used pliers.... the most difficult part of the whole thing was finding the hairdryer.
Even I could do this...
Cables that have never been treated with 'respect', (badly wound up, allowing the carrier cables inside to become so twisted that they are pushing through the outer sheathing).
