Hole in water system (1 Viewer)
Apr 14, 2019
7
14
Dorset, UK
Lo-Line coach built
Still learning…
Can anyone tell me what this is (the white tube on the right, which is cracked) and how easy it is to replace for a non-diy person?! Swift Escape on a Ducato. Just arrived at campsite and tried to fill the tank but water pouring out of the van.
TheBig1
17,653
43,486
Tis only a pressure valve as Lenny mentioned above. Any local caravan accessory shop should have a push on cap or straight joint to replace it for now. Drain the water and you simply push in the collar at each joint and pull the pipe out at the same time. Refit by simply pushing back in
stuartholmes
394
568
Nottingham
Murvi Morello
Since 1989
'push to fit' plumbing bits from any respectable plumbing shop - google 'plumbers near me', doesn't need to be a campervan shop as what you've got is assembled from standard house plumbing bits.
Shop should be able to demonstrate removing & fitting, no tools required.
Lenny HB
53,764
151,285
On the coast in West Sussex
Hymer B678 DL
It will be 12mm pipe, not avalible from plumbers merchants needs to be a caravan/Motorhome shop.
stuartholmes
394
568
Nottingham
Murvi Morello
Since 1989
Happy to be corrected Lenny, but last time I needed plumbing in the 'van was for my water filter & it was 15mm stuff.
Of course there's always amazon next day delivery...
Two on Tour
10,406
51,643
Elddis Autoquest 175
Since 2010
It's a Whale accumulator.
Check if the spigot is 15mm into the "T" if so then this is the one you want.
