A place in poland, i have been in contact with them this morning and can ship to Spain via DHL for 21 euros, so all in 773 euros delivered, as i say only rubber hoses - heres the linkAlugas are excellent €700 for 2 sounds far too cheap for Alugas, can I ask where from?
Be careful with the Gas Bank difficult to get the multivalve bottle see earlier posts in the thread.
It looks like you need to add the filler box housing too if you want to mount it externally, or some sort of bracket for internal mounting:A place in poland, i have been in contact with them this morning and can ship to Spain via DHL for 21 euros, so all in 773 euros delivered, as i say only rubber hoses - heres the link
2 x Alugas TRAVEL Mate - 11kg (25 Litres) Refillable Alu Gas Cylinder + remote filling point
ALUGAS TRAVELmate fillable with multivalvecarbonzorro.com
Yes - says it comes with a remote filling point just trying to establish what that looks like - as picture looks a bit unsightlyIt looks like you need to add the filler box housing too if you want to mount it externally, or some sort of bracket for internal mounting:
Euroconnector / ACME Filling Point Housing Box with Lock
Euroconnector / ACME Filling Point Housing Box with Lock | Autogas System \ Autogaz \ Pipes and hosescarbonzorro.com
Sorry yes saw that, but what i meant was, what it looks like in person so to speak - and i wanted a white oneIt looks like you need to add the filler box housing too if you want to mount it externally, or some sort of bracket for internal mounting:
Sorted….YouTube is your friend.Always alternate between the 2 cylinders as the construction / function of the fill stop valve requires a tiny bleed hole .
Unfortunately this means that over time every fill will add a tiny amount of liquid State LPG , you will eventually overfill the unused cylinder .
Yes it certainly should do .With the auto changeover, if I leave the cylinder I’ve been using all the time closed, will it just automatically open on the other cylinder if I only open that one?
No. it is a maximum of 2 cylinders @ 12,5kgs each- so 25kgs of gas. is ok.Does that mean me and everyone else with 14kg Alugas bottles are illegal in Spain?
Well mine would be 28kg if full.No. it is a maximum of 2 cylinders @ 12,5kgs each- so 25kgs of gas. is ok.
My mate turned up here some years back with 2 x refillables, 1 x 12,5kg repsol , 1 x 12,5 kg cepsa & an 18kg calor .
fortunately I helped him out by letting him leave the repsol & cepsa here.
They are the same company as the LPG shop in the U.K. I believe .A place in poland, i have been in contact with them this morning and can ship to Spain via DHL for 21 euros, so all in 773 euros delivered, as i say only rubber hoses - heres the link
It depends on which adaptor you have in the Alugas cylinder.That doesn’t look to be the remote filling point that is fitted through the side/skirt of the vehicle, it’s possibly one that can be mounted on a bracket in the gas locker.
Have a look on their website for the pukka remote straight and angled outlet fillers for Motorhomes - and yes, they are available in white.
Carbon Zorro is also the company trading as LPG Shop in the U.K.
As an aside, can anyone tell me which connector/thread is on the (L/H) outlet from the Alugas multivalve, as I’m going to need to get from there to an auto changeover valve (which I believe is W20?).
We use 2 x 6kg gaslow bottles, they last 4 weeks using the fridge on gas.
Alec here we purchased our gas set up from this company ie self fill system. Had no problems with fill up.Just found these GRP bottles with multi outlets/inlerts so they can be plumbed in. lightweiaght & a lot cheaper than Alugas.
They do 5kg, 7.5kg & 11kg.
Very often the German KLF fitting .
Looks similar to a U.K. 21.8 lh ( Also known as a Butane nut ) but it will leak
Problem with safefill is they are a single valve bottle so can't be plumbed in and that means lifting them out for filling.SafeFill. Ultralight, Can be demounted and used for BBQ. Also, much cheaper as you can use one SafeFill and one Calor.
6kg per 11 kg cylinder roughlyNone of them. Alugas and save a load of payload.
Defeats the object of refillables and a high chance of being refused to fill up particularly in countries where it is illegal to fill hab tanks/bottles.
Safefill. bottles ,as some stated “they are heavy to lug around” . They are NOT they are lightweight plastic.
