Fiat ducato air bag warning light is on…..AGAIN. (1 Viewer)
Dec 18, 2011
754
511
Hull
Autotrail 634
Since 2006
For the 3rd time in less than 12 months the air bag warning light is back on the dash.The last time was 6 weeks ago when it cost me £88 with crashdata to have the module reprogrammed.I did ask the question then why has it gone again.One of the replies it could be high voltage when starting the engine.So every time since the last replacement i have turned the ignition to on and waited until the various lights went off before cranking the engine.This morning i only tuned the ignition on to check mu LPG levels and almost immediately the air bag light came on.
I am at a loss what to do next.I cant keep paying £88 God knows how many times.Has anyone please got/had this problem and found out a reliable fix?Any help greatly appreciated.
May 21, 2008
4,289
7,378
Oxford
WildAx Constellation
Since 2008
My Citroen Relay one has been on/off intermittently for about 2 years. My garage turns it off (By fiddling under the passenger seat) but it always cmes back on again. I have learnt to ignore it as the garage says it doesn't mean anything.
890
1,973
Bishop's Stortford
Autotrail Delaware
Since 2011
Mine blew when I boosted the battery without removing the wires at the terminals. I read everybody’s comments and decided to have a new one fitted. One of the reasons was that I was travelling from Manchester to home at the time and would be passing Brownhills. I will be more careful in future.
My only regret is that I did not ask the mechanic to give me the damaged unit - maybe it could have been repaired and kept as a spare.
Lenny HB
54,034
152,386
On the coast in West Sussex
Hymer B678 DL
As long as you are happy driving without airbags.
Reactions: TCG
276
217
Apache Hi Line 634
Just had ours replaced with a new one (under warranty) - went for no reason (Fiat Ducato).
Camper634
Dec 18, 2011
754
511
Hull
Autotrail 634
Since 2006
This is an absolute scandal.They are obviously not fit for purpose.The so called repair specialists charge around £90 and offer no guarantee whatsoever.If/when i change my van the first thing i will have on my tick list is that it is on a Ford chassis and not a Fiat or one of its clones.
Lenny HB
54,034
152,386
Hymer B678 DL
Ford's have there share of problems as well, injectors often fail, far more expensive than an airbag ECU. Also much easier to nick.
You hear about Fiat problems more because the vast majority of Motorhomes are on a Fiat base.
Camper634
Dec 18, 2011
754
511
Hull
Autotrail 634
Since 2006
I can only go on my experience Lenny.My previous van was on a Ford and i did not have any problems in 5 years.Maybe I was lucky.Unfortunately the Ford option was not there when we changed vans.
MichaelT
3,182
5,947
Colchester
Carthago I 143 LE
Since 2016
Mine was £450 after haggling a discount.
We had ours replaced yesterday, it went a couple of weekscago in the cold weather. £216 for the part then £85 to program it then the dreaded VAT, £367 in total. This includes going in last week for diagnostic and fitting. I decided to go straight for new onecafter the stories of crashdata continuing to fail plus post strikes and I get a 2 year warranty. I asked if it was a common fault, he said they rarely fail on the vans but had a few on MH so I wonder if its something to do with the conversion or perhaps not getting used as much?
110
249
Calpe Spain
Benimar T483
Since 1980
FIAT used to be known in the trade as Fix It Again Tomorrow. Unfortunately this is still true for certain items.
Wheel bearings; Airbag ECU; Sump Corrosion, Screens and Scuttle are just a few that come to mind.
However our Swift van was problem free for 5 years. Maybe lucky but it was the last of the Euro5 chassis.
My last Boxer work van had all the above issues plus many more that often manifest themselves abroad but it did have nearly half a million miles on when it finally died.
We now have a new Ford base and it is certainly a step up from the Fiat on every front.
You pay your money and keep your fingers crossed.🤞
2,075
4,368
Since 2010
MichaelT, I think you've done well there!
We've only had one quote, so far - £767 diagnosed and fitted by Guest Truck and Van, Wolverhampton. 😵
Graham's going to ring round, today.
215
295
Chippenham, UK
Chausson 610 Welcome
Ex Tugger saw the light in 2019
Yes, it's a requirement at MOT for the light not to be illuminated. So your travelling down the motorway and the light comes on for what ever the vagaries of the system decide. Do you immediately stop because the airbags may or may not deploy in a crash? If the airbags are not going to deploy, then you have to call out recovery to get you back home because the vehicle is not safe to drive.
350
1,723
Sun Living S70 SC
I probably shouldn’t ask and am quite prepared to be shot down in flames but are there any stats on how effective air bags are in an accident or are they something that we have just come to accept in new vehicles? I do accept that there Is data supporting the use of seat belts and why they became mandatory.
I can understand the principles behind the air bag but perhaps we should all don michelin man suits before getting behind the wheel as a belt and braces approach.
Lenny HB
54,034
152,386
Hymer B678 DL
I d
OUCH!
Mine was £450, the unit was about £240 + VAT, they charged labour at £115 + vat per hour. I could only haggle £30 of the original quoted price.
busbuddy
1,302
2,930
leicestershire
swift suntor 630G
since 1994
I can’t believe someone hasn’t produced an illegal box to just bypass it. I don‘t want an airbag, but want an MOT.
I doubt you would need a box, just someone with the fiat software that can get into canbus and turn off the airbag system
I used to have the vcds for vw when I fitted a TDI in a non TDI van, you had to go into the canbus and turn pretty much everything off bar the engine stuff
TheBig1
17,666
43,548
Yes there are well documented stats from NCAP from all the crash testing to absolutely proove that survivability and less injury results from the use of airbags. If you ever want scaring look up the motorhome crash tests on youtube. Just as likely a fridge will kill you in a crash as going through the windscreen
2,707
2,171
Northampton
Rapido & Bongone
I thought i seen one on ebay a few years ago. It was basicaly a timer and relay that light the lamp with ignition on then switches off after a set time. Better than plasticine or removing bulb as it lights up on ignition.
Still do
TheBig1
17,666
43,548
197
360
Wirral
A class Hymer 504
Since 1995
Just before Christmas I had my air bag replaced by South Liverpool Commercials - Fiat Professional side. Cost £418.34 including VAT. Excluding VAT, the breakdown was Unit £273.62, labour £70, and consumables £5.
SLC say they replace the units in Fiat motorhomes from time to time but cannot recall replacing a unit in a commercial Fiat van they service.
Thanks for the tip off, Lenny.
2,707
2,171
Northampton
Rapido & Bongone
Peeps, Google Carprog……..you’ll probably find it’s the programmer the likes of crash data are using to re-program the EEPROMs Inside the airbag ecu module.
Cost you about 100 quid to buy the hardware from flea-bay…..but it’s probably not for the feint hearted.
Theres youtube videos out there too 😉
A group buy and forum ran service could work for you tho……..👍🏼
I asked about this type of application a couple of years ago. Thanks for the info. £90 hey ho, if mine goes this is where my first £100 will go and not to crash dummy R U.
Gerwyn195
Fiat chausson627
There only seems to be two airbags in a Ducato. Possibly because they are not a legal requirement in commercial vans.
I can't see or understand how the seat knows it's occupied or not
if it's not a legal requirement in vans, can you explain why it is a MOT failure if the airbag warning light is illuminated on the dashboard please??
6,843
12,620
Herts.
Adria Coral lowline
Because, like many things on the MOT list, if fitted it must work.
