Checking tyre pressures (3 Viewers)
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
I have been concerned for some time about the accuracy of air lines at garages and would like to be able to check the tryre pressures on my mh myself and inflate them to the correct pressures.
What equipment do you all use or do you rely on the garages?
Norman
Jim
Ringleader
Jul 19, 2007
36,429
130,934
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Hi Norman
This is a great guage but a bit expensive Link Removed
I have one of these, which does an excellent job it includes the pump and guage, you can set the pressure and go and have a cuppa, it stops at a pre-set psi Link Removed
Once pumped up, these are a Link Removed :winky:
Chris
21,056
278,796
10 years
I checked my pressures yesterday on the van and one of my tyres was 3/5 of what it should have been:Eeek:
This is the same wheel I had the blowout on in the Summer and the old tyre used to deflate a lot quicker than the others.
Is it possible the wheel is defective in some way?
Aug 27, 2009
19,792
23,071
Hertfordshire
40 years
You could always put some bubbles around the rim and valve, could id a leak.
2,335
10,112
If it's an ally rim.. yes.. not unknown for them to have a porosity fault...
very unlikely with a steel rim.
More likely is a faulty valve stem or you have been unlucky and have a nail in the tyre.. best to have it checked at a tyre depot.
2,335
10,112
golly
2,006
69,617
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I have both the Michelin and the Draper gauges. I find the Michelin a bit fiddly to use, you need to get the angle spot on or you loose a load of air just checking the pressure, I prefer the Draper gauge.
Bailey58
8,817
29,590
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
One of these has given me good service, don't know how they sell them at the price.
Nor do I , good bit of kit .. :thumb:
on offer here at £7.80 inc delivery
http://www.drapertoolbox.co.uk/drap...n=GoogleBase&gclid=COjvp7v6irUCFePHtAodgTQAiA
I've got the same one, reaches places other gauges struggle to on some wheels. :Smile:
Jan 13, 2008
107
34
Cardiff
Concorde Charisma
Since 2008
I used to own a car that always lost air in the front tyres - turned out that the previous owner didn't slow down for speed bumps so the alloys had developed hair line cracks. I had them refurbed and they were brilliant... for a while until the same problem returned. Ended up having to replace the wheels :cry:.
Not sure how you would check the wheel plus tyre for leaks.
Gunner29
836
610
Plymouth
Low Profile
silly Q
how do you know if the Draper gauges are calibrated to the correct pressures? very good value so may invest in one
normanandsue
normanandsue
1,871
21,571
van conversion
Hi Norman
Once I get pressures stabilised that is my next purchase.
Norman
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Great
Hi Norman
Oh that's worth paying the subs for in itself. A simple tyre pressure monitoring device with a LED. £35 for four - quite a saving on the other, fuller systems!
Dec 24, 2009
1,072
15,721
bedworth warks
c class
2009 previously a tugger for thirty years
I am not sure if it is still the same, but Sainsbury's tyre pressure gauges always used to be calibrated on a weekly basis.
My mate and me always used to go there before we went out for a run on our Honda Blackbirds, when we were on occasion accused of making progress LOL :ROFLMAO::ROFLMAO::ROFLMAO:
