The waste in the shower has a dome/cap on it, which makes it difficult to clean, and also difficult to put a filter/sieve on top to catch hairs etc. No idea whether this is a common fitment on Pilotes. Anyone sorted this problem? Picture below.
Yes, it is a push fit and fingernails under the metal coloured edge where it meets the shower tray will pull it up for cleaning. It is amazing how much gunk can build upThe waste in the shower has a dome/cap on it, which makes it difficult to clean, and also difficult to put a filter/sieve on top to catch hairs etc. No idea whether this is a common fitment on Pilotes. Anyone sorted this problem? Picture below.
You mean the whole thing pullls out? What holds the trap to the underside of the shower tray then? Not doubting you, just confused.Yes, it is a push fit and fingernails under the metal coloured edge where it meets the shower tray will pull it up for cleaning. It is amazing how much gunk can build up
Yes it does. Lifts up, exposing the trap and a removable cup thingy. Give me 5 minutes and you will have a photoYou mean the whole thing pullls out? What holds the trap to the underside of the shower tray then? Not doubting you, just confused.
Not on that one it doesnātNo, just the middle chrome button head. It may seem stiff, but eventually it will part from the main body of the shower drain.
Ok, I will try it carefully in a couple of days when our trip is over. Ours is different to the one in your picture so I'm a bit nervous. Thanks for taking the trouble to get pictures.Yes it does. Lifts up, exposing the trap and a removable cup thingy. Give me 5 minutes and you will have a photo
Youāre welcome - it looked identical. Nothing to be lost by trying ā¦.. apart from a fingernail. It is quite a tight fitOk, I will try it carefully in a couple of days when our trip is over. Ours is different to the one in your picture so I'm a bit nervous. Thanks for taking the trouble to get pictures.
There's no way the centre piece comes out on it's own. It's all one casting with the outer flange. So logically, the whole thing comes out. Famous last words......acropolis22 - ours looks like it may be the same as yours. Never been able to remove the centre part so have resorted to āfishingā with a skewer! Itās a bit of a faff but seems to work ok.
Give it a goā¦.. as I said, the fit is tighter than Kevinās Keenanās football shortsThere's no way the centre piece comes out on it's own. It's all one casting with the outer flange. So logically, the whole thing comes out. Famous last words......
Sounds like an interesting plan, but I have no idea what you mean.Try bending the end of an old flat screwdriver over to form a lip and then fish it to the bottom and pull up from there moving around the circle it should come out and no risk of pulling the top off
Ok, I get it now. We are back home tomorrow, so I'll give it a go. Thanks for the tip, and thanks also to DuxDeluxeSorry I know what I mean but not easy to explain, if you have an old screwdriver and bend the tip to form a 90deg lip then drop it in where the water drains out then twist it so that the lip is under the lowest part of the chrome part then pull up you will in effect be pushing from underneath not pulling from the top so not risking it breaking off in your hand, as it starts to move just work all the way around so that you are getting an even pull up, if you stay in one place it will wedge and the get even tighter, if this happens push back and start again, I expect there will be an O ring in there so it gunks up and really gets hold, once you have everything out clean well and apply some silicone grease from Scewfix or somewhere similar to the O ring and surrounding surfaces, best plan is to take it out regularly as that stops the build up which is the main cause of the resistance.
Hi Acropoplis, we have a 740 Evidence did just the middle come out or the whole chrome bit ,as I need to clean mine as well.So, after all the discussion about how to remove the waste and what bits come out and what don't, I just grabbed the sticking up cap bit, gave it a tug and the whole thing came out quite easily. You don't want to know what it looked like inside. All now cleaned out and replaced. Many thanks to everyone for suggestions and information. Without you I would never have enough thought to try to pull it up.
The whole thing. And there is a plastic cup inside that also comes out. But I have no idea whether yours is the same. Did you see the photo in my original post?Hi Acropoplis, we have a 740 Evidence did just the middle come out or the whole chrome bit ,as I need to clean mine as well.
Pleased you got it fixed. It was a leap of faith the first time I tried it - it does sound the same as mineThe whole thing. And there is a plastic cup inside that also comes out. But I have no idea whether yours is the same. Did you see the photo in my original post?
I think yours is more modern. The dome is bigger. Same basic idea though. Any idea where to get replacements? The chrome is on it's way out on mine.Pleased you got it fixed. It was a leap of faith the first time I tried it - it does sound the same as mine
Mine was 2014. Sorry, can't assist with the sorting, but will have a lookI think yours is more modern. The dome is bigger. Same basic idea though. Any idea where to get replacements? The chrome is on it's way out on mine.
I have a 2020 P650 and it's the sameIs it the same for a P650 please? I never even thought about it till I saw it mentioned here.
