OldCodger
The lever by the passenger seat doesn’t open the bonnet - it pulls tight (so the cable isn’t broken) but the bonnet doesn’t lift. Any hints ? (I7400 Merc A class)
At least anyone stuck has got time to do it!Can be a bugger of a job, have done many over the years when I ran my garage and even similar cars can be very different to access the bonnet release cable, First try where the cable joins the lever inside the car using a vice grip to pull directly on the cable, next put car up on your levelling ramps to gain access to the underneath, look up behind the radiator and see if you can locate the cable or bonnet lock,
Last thing to try is going in through the grill/ Bumper to get access, you may be lucky but usually it’s a pig of a job,
I had same problem when (if) you get it open by pushing down , it should be possible to adjust the end by the bonnet catch to increase the amount the inner cable can move.The lever by the passenger seat doesn’t open the bonnet - it pulls tight (so the cable isn’t broken) but the bonnet doesn’t lift. Any hints ? (I7400 Merc A class)
Centre for my Merc. I guess most are centre.Thanks all. Where are the catches ? In the centre or at the sides of the bonnet ?
Thats what fixed it Thank you.On our Frankia the bonnet doesn’t “pop” when cable is pulled. I have to pull the bonnet forward. It’s released ok and catches back when lowered.
Thankfully the cable is OK and everything looks well lubed. I’ll keep an eye on the strecth in future though.Cable has streeeeeetched.
Pull lever, ask someone else to rattle the bonnet edge.
open bonnet, adjust cable and lubricate catches, cable etc
Worst case scenario, take to a garage and they will release it from underneath.
As I suspected. But it shouldn’t be like that,as no good if there’s only one of you around when it needs lifting.Thanks Everyone. What I hadn’t understood was it doesn’t Spring up like on the car! If Mrs Codger pulled the lever I was able to raise it by hand! ( )
Not that i can see. I’ve now sprayed all the hinge points with WD40 silicon And it moves a lot easier.Should be a coil spring on the bonnet catch pin.
When the bonnet is closed the spring is compressed, pull the release and it pushs the bonnet up.
Is the spring broken?
Excellent. Thanks. A part number is a massive help!Here's one but it is in the States.
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=402256201273
Many thanks. I found them but the website crashes on me!
Actually it was Google .Many thanks. I found them but the website crashes on me!
Follow Up: I eventually got in using Chrome instead of Safari. I found the part, let’s hope they can source it. I’ve emailed them
Thank you and Two on Tour between you you solved my problem!
I’d spent an hour plus on google before I asked , so you really did help!Actually it was Google .
