And question two - how do you get the bonnet open ? (1 Viewer)
OldCodger
854
202,124
Surrey, UK
Carthago I 143 LE
Since 2016
The lever by the passenger seat doesn’t open the bonnet - it pulls tight (so the cable isn’t broken) but the bonnet doesn’t lift. Any hints ? (I7400 Merc A class)
Feb 21, 2016
4,922
29,742
Uk
C class
Since 2017
Snatch it harder.
Just a thought........is it already released but bonnet hasn’t risen to the second catch,for some reason?
MattR
4,105
39,188
Beds
Panel van
Years
As others say, push down on the bonnet and pull the lever. I've done it on my own (pushing down and then pulling the lever) but it is more effective to do it when someone is pushing down at the same time as someone pulls the lever.
Jan 22, 2013
1,257
60,774
London SE
A class Adria vision I707
since 1971
Can be a bugger of a job, have done many over the years when I ran my garage and even similar cars can be very different to access the bonnet release cable, First try where the cable joins the lever inside the car using a vice grip to pull directly on the cable, next put car up on your levelling ramps to gain access to the underneath, look up behind the radiator and see if you can locate the cable or bonnet lock,
Last thing to try is going in through the grill/ Bumper to get access, you may be lucky but usually it’s a pig of a job,
Mar 23, 2012
9,582
32,234
sleights
c class
At least anyone stuck has got time to do it!
Euromobil
237
793
hampshire
Adria Coral
Since 2010
I had same problem when (if) you get it open by pushing down , it should be possible to adjust the end by the bonnet catch to increase the amount the inner cable can move.
Campervan_man
997
1,720
Dethleffs Globebus
Cable has streeeeeetched.
Pull lever, ask someone else to rattle the bonnet edge.
open bonnet, adjust cable and lubricate catches, cable etc
Worst case scenario, take to a garage and they will release it from underneath.
OldCodger
OldCodger
854
202,124
Surrey, UK
Carthago I 143 LE
Since 2016
Thanks all. Where are the catches ? In the centre or at the sides of the bonnet ?
Chipster
1,008
1,121
East Midlands
Getting there!
On our Frankia the bonnet doesn’t “pop” when cable is pulled. I have to pull the bonnet forward. It’s released ok and catches back when lowered.
icantremember
8,341
17,566
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Mar 29, 2011
961
639
Rugby UK
C Class RS
After my Iveco was standing for a few weeks I could not get mine open, I did not want to apply too much pressure so I left it to a warm day and got it open and its been fine since, I now open it every 2 - 3 weeks to put the charger on the chassis battery.
Jun 30, 2010
7,925
27,239
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Get that some times with the T4 VW, have learnt to give the bonnet a bit of a lift first, then pull the lever.
OldCodger
OldCodger
854
202,124
Surrey, UK
Carthago I 143 LE
Since 2016
Thankfully the cable is OK and everything looks well lubed. I’ll keep an eye on the strecth in future though.
Feb 21, 2016
4,922
29,742
Uk
C class
Since 2017
Thanks Everyone. What I hadn’t understood was it doesn’t Spring up like on the car! If Mrs Codger pulled the lever I was able to raise it by hand! ( ;) ;) )
As I suspected. But it shouldn’t be like that,as no good if there’s only one of you around when it needs lifting.
Maybe it needs a bit of lubrication to help it pop up.
OldCodger
OldCodger
854
202,124
Surrey, UK
Carthago I 143 LE
Since 2016
I’m off to get the WD40 for the hinge mechanisms
43,367
49,720
Should be a coil spring on the bonnet catch pin.
When the bonnet is closed the spring is compressed, pull the release and it pushs the bonnet up.
Is the spring broken?
OldCodger
OldCodger
854
202,124
Surrey, UK
Carthago I 143 LE
Since 2016
Not that i can see. I’ve now sprayed all the hinge points with WD40 silicon And it moves a lot easier.
The bonnet does actually “unlatch” when I pull the lever. It just doesn't jump forward. I can pull the lever and although there’s no apparent change, the bonnet can be lifted. I just walk to the front and lift it: it Is a bit of a fuddle getting started, but once it’s started to move it is all fine.
OldCodger
OldCodger
854
202,124
Surrey, UK
Carthago I 143 LE
Since 2016
Anyone know where I can get a replacement cupboard catch? The D-Shaped on one of the kitchen cabinets has broken. It has the name Southco on it. I’ve googled it and it seems to be a specialist company based in the US. I can’t find the exact model for sale anywhere. Anyone got any ideas?
68c
Oct 22, 2019
1,822
2,804
Southampton
2001 Pilote 270
Since 2004
Working in Nigeria, had an old Datsun in which the bonnet was inset at the front rather than overhanging the grill like most cars. Closed the bonnet and sat on it to click it home, caught by shirts in the bonnet! Took quite a while for my Nigerian colleagues to stop laughing and finally release the white man.
OldCodger
OldCodger
854
202,124
Surrey, UK
Carthago I 143 LE
Since 2016
