Alko DIY wheel carrier (6 Viewers)
Techno
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
MK II model
Mark II model
Better use of materials now experimentation with prototype complete.
Weight 11kg before paint
duane0001
792
778
East Coast, North Yorks
Expedition 67 soon!
2021 This time
You are certainly very thorough in your design and implementation
If I could add my 2 pence worth,
I would use high tensile bolts on the bar ends to bolt it too the chassis as I think the weight of the wheel will try to twist the whole contraption and maybe lead to complete failure of the bolts, what do you think?
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Thank you but it cannot twist as it is tight to the underside of the floor.
The wheel causes no twisting force either as it is centered and balanced.
It has a downward weight of 30kg
EDIT the angle to chassis bolts are 10mm BTW and 30kg even if it could twist will have little effect on 4 X 10mm
rikfos
315
199
hereford
There are some really talented people on this community:thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Is there a way of telling that the mechanism is the latest one and not one that was subject to recall Andy ?
Just thought it may help anyone thinking of doing similar.
As usual great pictures and very helpful info:thumb:
mentaliss
654
306
Lancing
I discovered a bonus which was promted by a question I was asked
Whilst dropping the wheel today to extend the hot water dump pipe
I thought about the question and fully unwound the cable to discover it will reach the nearside of the van
It also winds back up from there too!
A bit of added security
Andy do you know that the long shank padlock actually helps you unwind the cable release in the event of not having the key tool..... I use a long carbon pin that jam's against the chassis which has to be removed first but then if a thief is well determined they get that wheel:Cool:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
That guide tube rotates independantly on mine, has no effect on the winder at all. It just rotates to accomodate a padlock from any angle.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Its not a hex key it's 5 sided and yes removing the padlock allows you to insert the drive tool that will actually wind the mechanism. the guide sleeve will rotate but it will not rotate the winder. You are misguided.:Doh::ROFLMAO:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
What I would really like to see is you trying to lower my spare by rotating the padlock :roflmto: Houdini
mentaliss
654
306
Lancing
Misguided?:Doh: what are you putting a padlock through the guide then??...if you block the guide entrance you can't insert the key, right:Smile:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
This is the issue you raised are you now back pedalling ?
I don't think I'll persist in responding it's just cluttering up a good topic
mentaliss
654
306
Lancing
Sorry Andy we seem not to to be on the same road:ROFLMAO: its not a question of back pedalling its not me who trying to score points, we all know what a clever d... you are but so am I :ROFLMAO::ROFLMAO:..if you grasp the guide barrel that your padlock is inserted into pull it down towards you the barrel grips the spindle and you can turn it sufficiently to release the cable lock ..mine does anyway! two other MH's I know who have this device fitted does this.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I'm building one of these soon bespoke ( by request) for another Rapido 7 series on alko but with 15" wheels. I'll report on any problems if I encounter any.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
16" tried and tested in background
15" basic components in foreground ready for measurements and cutting.
Spare wheel will be needed to discern correct spacing for hanger and sufficient spring tension.
I've found a good source of 2014 mechanisms if anyone wants pointing the right way just pm me
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
15" complete without issue so far. The 7 series Rapido that this is going on is basically the same as mine but with 15" wheels instead of 16, the Alko chassis rails are the same 260mm depth. Often the lighter chassis used are shallower but fortunately not in this case. The width is the same at 1285mm rail to rail with the 2" cut out at each end to accomodate the C profile.
The tyre being narrower at 215 also means less spacers to attain the right tension on the hanger spring.
Here the 16" 225 75
and the 15" 215 70
The smaller diameter allows the hanger to move a bit closer to the nearside to to afford easier wheel retrieval
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Not wishing to be overly critical but that 7 series Rapido looks like its modeled on a park bench
You need to get them patented but dont know what colour to suggest :LOL:
Nice job(y)
Sep 29, 2012
83
463
Wakefield
Low profile
Thankyou Andy what a briliant job and invention we now have much more room under the bed without the spare wheel taking up so much room quality work as usual
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Anyone want to attempt your own? pm me for contact details of a seller who has 15 & 16 inch units (back in stock) @ £70 delivered. You deal with him by paypal
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Fitting this padlock over 3 yrs ago has proven to be a frivolous folly and my recent attempt to check the wheel was met with a completely seized barrel. So I have just drilled it out at this meet at Rufforth and discarded it.
The wheel deployed effortlessly after all this time (y)
My tyrepal monitors the pressure.
EDIT and no it is still not possible to lower the wheel by rotating the padlock :LOL: and I'll put any money on it.
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
Hi Andy,
Really good job, looking to fit to Al - Co on Dethleffs. Did you size hollow section to suit mechanism, and did you blind drill top face for bolt fixings. Found supplier on e bay £47 including delivery but I had to push for winding rod.
Jim
