Pictures in post 17 should explain.That is brilliant how you have fitted the spare wheel carrier, will this fit a aluminium wheel
Having an Alko does not mean there is space for oneThis is great just had to use spare from a fiat chassis with this kit fitted but swapping to an alko shortly and now I know how to fit a spare to it
I think it was 100x50
Steel cannot flex as its fixed at both ends
Picture 54 steel gives tyre three points of contact
Hi.
Thought I would drag this thread up again rather than create another post
Still planning on getting the spare wheel out of the way on my '57 747 Tag and @Techno 's design is probably the way forward but searchin around for info I found this:
https://www.al-ko.com/shop/uk_vt/spare-wheel-carrier-for-16inch-wheels-1.html
Is this too simple, will this not fit?
This would seem a lot simpler system. I need to crawl underneath to have a good look/measure up and hope to this weekend when I am away in it as I'll be on grass and the storage place I have it like a third world dirt road to lay on.
I'll measure it tomorrow but it's not much lower that the side rails of the Alko and if it drags on the speed bump, it's made of pretty big steel so it will just scrape the hump.....Interesting topic for me at the moment.
I’m thinking of putting spare under mine, but it leaves me with about 210mm clearance below, which I’m unsure is enough.
How close is yours to the road?
Andy.
