Yes no problem, just make sure it doesn't go dead with the light switchHi can I simple cut into the light wires and come off them to a usb socket near my bed ?
is there any reason why not
Yes some are really poor quality and I avoided them for years, recently though I found some that seemed good quality aluminium cased and QC3 compatible. I bought one and tested it for interference and how warm it got charging a tablet, it was good. I'll get a link.One thing I never do is charge anything overnight ... ever ... there are risks involved when charging and I'd rather be awake and able to deal with it if needs be than fast asleep. Some people have used some sockets off Ebay which have developed faults so it's not a myth.
So the wireing system will go dead when switch is off so I have to charge when lights on I guess I may have lights with switch so could turn off from each oneYes no problem, just make sure it doesn't go dead with the light switch![]()
Corrrrr ... they're a bit 'tasty'
No, you just cut into the live wire leading to the light, the light being on/off won't make any difference unless you inadvertently use the negative wire - you need to check which is the live and negative wires so you know which is which.So the wireing system will go dead when switch is off so I have to charge when lights on I guess I may have lights with switch so could turn off from each one
