Window Stays (1 Viewer)
AdieP
5
Stjohn54
Hi hoping someone can help. I have a Globescout Roadscout R and one of the levers has snapped off a side window stay. Does anyone know how i can sort this. I dont seem to be able to remove the broken part of the stay from the window and im not sure what replacement part I would need. I anyone can help it would be much appreciated.
A
AdieP
5
Stjohn54
Good idea.
Dec 12, 2010
5,431
21,706
Cumbria
since 2011
Just check there isn't a small hole on the underside that you can poke a thin wire (paperclip or similar) that will release a small internal latch, then you can slide the handle assembly off ?
TheBig1
17,649
43,467
you need to look on ebay for a seitz window stay of the same length
A
AdieP
5
Stjohn54
Thats great, will look tomorrow, thanks for your help.
A
AdieP
5
Stjohn54
Found the small hole and tried to release the catch but no joy. Tried also in a non damaged stay but still couldnt release the catch. Is there a knack to this?
Aug 1, 2021
985
5,760
Pembrokeshire, UK
Auto-T Expedition 66
No knack as such. What you are doing is right. Use a thin, sharp point to press into the little hole. This releases a barb inside the black plastic mount attached to the window, allowing for the mount to slide off the window. You don't need to apply much pressure into the hole to release the barb, but you may have to apply a bit of force to slide the mount off. It only slides off in one direction, so if it won't go one way, try the other.
Also, it's easier with the window held slightly open with the knob untightened thus allowing the mount's required sliding movement.
A
AdieP
5
Stjohn54
Thanks for the response. Unfortunately when this first happened i tried to repair it with superglue, not a good move. Ive tried some superglue solvent, but I stilI cant release it. Not sure if this is reason why Im struggling. Im thinking it might have to be cut off. I have a multitool which might do the job but a bit nervous of tackling it this way. Might be better to find a professional.
Dec 12, 2010
5,431
21,706
Cumbria
since 2011
Try using a small Allen key (1.5mm/1/16" size) it might need the stiffness to push the little prong out of the way ?
Aug 1, 2021
985
5,760
Pembrokeshire, UK
Oh dear. Superglue will definitely not have helped. You will have bonded the mount to the backing plate which is screwed to the window, preventing it from sliding off.
