Post 18
Actually you did, this is what you wrote:I did not state 1000 amps I quoted 93 amps!
This is what you said at #18I did not state 1000 amps I quoted 93 amps!
the charge rate from the alternator peaked at 1123 amps we do not have a B2B
I was advised to use the LA settings on my Nordelectra 237, which I'm sure is different than yours, but I've also read recently that while it will charge it up ok to within 98% of capacity, which is actually the case and I'm happy with that, if the lithium gets too low and it then gets connected via EHU, it can damage the N237 because it's working that hard to fill up the lithium. Applejack suggest making a mod to the N237 to prevent that at a cost of £140.Steve, can I ask what settings you were advised to charge your Lithiums on please? Some say LA, whilst others say Gel.
My 60A B2B has a Lithium setting, so 100% charge would be achieved periodically.
Cheers,
Jock.![]()
Dave, if and when I do go ahead with Lithium, I was thinking of maybe isolating the CBE mains charger, to see how I'd get on with just solar and the B2B.I was advised to use the LA settings on my Nordelectra 237, which I'm sure is different than yours, but I've also read recently that while it will charge it up ok to within 98% of capacity, which is actually the case and I'm happy with that, if the lithium gets too low and it then gets connected via EHU, it can damage the N237 because it's working that hard to fill up the lithium. Applejack suggest making a mod to the N237 to prevent that at a cost of £140.
I think others have removed the relay themselves to prevent it and installed a separate charger, but I would probably have mine converted at Applejack as I wouldn't know what to do!
I also intend on definitely fitting a 60A B2B when we get back, hopefully before the Halloween Rally, but if I do then my thoughts are that after driving an hour or two between park ups as we usually do and then go on site, which isn't often, and use EHU then it shouldn't take much charging ..... so is the Applejack modification really necessary if all it's for is to protect against something that shouldn't happen ...?
That sort of ties in with my thinking, but so long as I'm not making the existing on board charger work too hard, then I'm not sure I need to disconnect it or even have it modified. It charges perfectly well up to 98% or so via EHU, which for me has been shown to be enough and occasionally it gets to100% with solar. You have a large B2B so if you're moving around, even an hour's driving will bang in more power than you will prob use during one day off EHU.Dave, if and when I do go ahead with Lithium, I was thinking of maybe isolating the CBE mains charger, to see how I'd get on with just solar and the B2B.
Cheers,
Jock.![]()
Yes Dave, but it would just be a flick of a switch to turn it back on, so would possibly only be used in winter on the odd occasion we are ever on EHU, ie, where little solar power is being produced. If it was found to be unsuitable, or not able to cope, I'd just replace it with a Lithium compatible mains charger.If you disconnect your charger though, would it stop you charging up when on EHU? Is that something that would have any impact!
I think I prefer my current setup Dave, ie, 2 x battery banks which can be isolated from each other at the flick of a switch, and would therefore prefer 2 x 150A or 2 x 200A Lithiums. If one battery goes belly up for some reason, I've still got half my initial capacity to keep me going.If I went through the process again, I would buy a 400Ah battery, with your beast you could carry something that big without worrying about the weight.
Ok my setup is different to other on here because I have 2 alternators at different voltages but the hybrid is working pretty well for me. I hardly ever use the new main charger I bought.Yes Dave, but it would just be a flick of a switch to turn it back on, so would possibly only be used in winter on the odd occasion we are ever on EHU, ie, where little solar power is being produced. If it was found to be unsuitable, or not able to cope, I'd just replace it with a Lithium compatible mains charger.
Cheers,
Jock.![]()
