American Dream
Are you sure about this - most RV gennys run from the engine battery on the basis that if you run down your leisure batteries you've still got power to start the genny and charge everything up. Try what someone suggested - run the engine then try to start the genny.
Are you trying to start from a switch in the cab or on the genny? I had a genny that occasionally wouldn't start from the cab but would always start from the switch on the genny itself.
Keith
Good point Keith.
Mine starts from the main engine battery too, for just that reason.
Will the RV start/run ok?
If the genny ran before the service and all that's been done is to change oil/filter and plugs, it should run now.
Has a fuel line been trapped/disturbed during this, or a wire been pulled off?
