2657
I have a 20w mountable framed panel.![]()
So have I, foldable, used it to keep the 5'er batteries topped up when we stored it for a couple of months in France, not used it for a few years.
I'm gonna rip em off and put 2 x 100w panels on.Slightly off topic, 40W solar panels are not going to give you anything like enough power. I would consider changing them to something a lot bigger.
I have this in addition to the 125W fitted to my roof.So have I, foldable, used it to keep the 5'er batteries topped up when we stored it for a couple of months in France, not used it for a few years.![]()
Hi pill. . How does that work... I'm assuming your fixed panel and portable both have their own and different regulators.. and the regulator with the higher voltage would do the charging..I have this in addition to the 125W fitted to my roof.
http://www.photonicuniverse.com/en/...ny-other-12V-system---German-solar-cells.html
I measured the current going to my leisure batteries last week and was getting a total of 8 amps and it was not the brightest of days, so very chuffed with that.
Frankly, I am not interested in the least bit in what one needed/fitted/used years ago.
I am interested in now.
I have lived in a van fulltime for nearly thirty years and have fitted and used solar panels for twenty of them.
I have never fitted an in-line diode.
Mind you, I have never had a habitation check, never weighed my van, don't use a sign thingy on my bike rack and drive in bare feet in Spain...
Just saying
JJ![]()
Is that compulsory?![]()
Just curious as I have a 80w portable which could be plugged in but assumed my fixed 100w panel with its mppt controller would prevent the 80w with its pwm controller from working...
Ta Andy. .
No... it is illegal and as the "Worriers" on here will tell you, it will lead to you being thrown into a filthy, Spanish jail or fined by a policeman with a gun who needs to make up the monthly quota of cash taken off tourists...
JJ![]()
Cheers Martin Steve and phill ...that makes sense. .. basically if there is sufficient load and demad the 2nd controller will supply current...Hi Andy
We have three matched panels on one controller and a fourth on its own controller, as long as there is more charge demand than one controller can supply they both work to full potential, when the battery bank nears charge and the controllers start to cut back the smaller one goes to sleep and let's the other one take over, I took advice from Votronic before doing this and they said it was perfectly OK and it is.
Martin
