- May 16, 2021
- 1,344
- 1,918
- Autotrail
not sure what you mean by "real AES". Far as I am concerned, they are both "real".It can be done via dip switches on the pcb, no need for a mk2-3. And before the multiplus was on phoenix, and before the phoenix was on the Atlas. All with dip switches. On later multiplus the search mode was added, the real AES is totaly diferent to the search mode. AES runs on reduced switching, resulting in less power draw. Search mode cycles every 2s but at full switching, so sine wave is maintained.
On the settings via VE.Config, there are two different AES modes available (and Victon would probably say they are both "real" as they are there to be used and listed under AES)
AES by David, on Flickr
One has the inverter running on a MSW mode (in effect reducing the load); the other cuts the power and checks for a load every couple of seconds.
The latter is the more efficient, but the MSW one can actully be quite handy in some circumstances (for example, if running a 240V fridge, it could allow the interior light to still work when the inverter is officially off, albeit at a reduced brightness as it is getting around half the power).
