Nedge68
Found it…
Sections 708 & 721 of the wiring regulations BS7671:2018
708 for Sites
721 for Motohomes
708 for Sites
721 for Motohomes
try the assassins teapot instead.Can you point me to this as I'd like to buy a deadly tea cosy for someone and want to get the right one!
Sounds like your neutral was bonded to earth?? But "EHU earth" not connected so neutral was floating the chassis voltage up.A chap removing a wheel from my motorhome on a site complained of getting a shock from the wheel, not a serious one but enough to feel. By the time he'd finished panicking and demanding an electrician I had found the problem a disconnected earth in the ehu plug.
It was obviously a low voltage shock and presumably was between neutral and earth, where unless they are bonded there may be a small voltage. In this case the earth was disconnected so the usual bonding didn't apply.
Victron Multiplus do this bonding when EHU is connected. See section 7.4But I can't imagine anyone connecting a Neutral (i.e. Neutral on an AC system) to a Bonded (i.e. Chassis) point. That seems like a very odd thing to do.
I suspect and I may be wrong on this that bonding the neutral to earth inside the vehicle should be avoided except in particular circumstances?
And to add more confusion with wires, services and colours.There is sometimes a mixing up of terms with electrics. quite a lot of people use the term "Neutral" when they mean either "0V" or "-VE" on a DC system. And people also use Earth when they mean "0V" or "-VE" on the DC system. Mixing terminology can lead to a lot of confusion.
And of course there is no "earth" on a vehicle unless it is connected via EHU to a supply with a ground/earth connection. "Chassis" would be the term for a bonded connection on a vehicle.
Certainly it is common to connect the PE (Protective Earth) connection on a AC EHU plug to the vehicle chassis. And also to connect -VE on the DC system to the vehicle chassis. And with the typical Consumer Unit, the PE on the EHU is also physically continued to all the AC circuits.
I was just thinking about the Multiplus there is a link in them that bonds neutral to earth to enable an RCD to work on the inverter I see from that info there is a relay that disconnects the bond when on the grid and it then relies on the grid bonding.Victron Multiplus do this bonding when EHU is connected. See section 7.4
I can't understand why you would do it to be honest which I why I said this.
This is why I hate seeing mains flex used on DC circuits. I don't understand why so many dealers use it when adding circuits such as Solar.And to add more confusion with wires, services and colours.
The incoming EHU Earth is coloured Green/Yellow and Live is Brown.
The 12v -ve (terminals numbered 31) in DIN standard automotive wire colour is Brown!
To those who are not aware of this they could assume that the EHU Live was bonded to the Earth.
OMG….240 VAC is a lethal voltage and will kill. Do you really know better than the regs? I would suggest for safety you don’t tamper with what you don’t understand.My point was RCD'S do not guarantee safety, a little common sense has to be used. Unless you have other problems a240v shock won't kill. My wife recently had a severe shock when an expensive RCD shorted to earth, the earth stakes were dry and the taps were live. They were live because the regulators say taps must be earthed for safety even when the pipes are plastic. For safety I did away with the RCD.
Cheap, using 1.25mm2 mains cable will be cheaper than using 4 or 6mm2 auto cable.This is why I hate seeing mains flex used on DC circuits. I don't understand why so many dealers use it when adding circuits such as Solar.
I agree. I use brown/blue/yellow-green for AC and black/red for DC in my self builds.This is why I hate seeing mains flex used on DC circuits. I don't understand why so many dealers use it when adding circuits such as Solar.
I follow the example of my Hymer wiring, which is white 3-core flex for 240V, and black 2-core flex (brown and blue) for 12V DC. Brown is DC negative (chassis).This is why I hate seeing mains flex used on DC circuits. I don't understand why so many dealers use it when adding circuits such as Solar.
lovely idea. Except brown is used for +12V very often as well.I follow the example of my Hymer wiring, which is white 3-core flex for 240V, and black 2-core flex (brown and blue) for 12V DC. Brown is DC negative (chassis).
It is recommended that in a motorhome where 240V and 12V wires coexist, the 12V wiring is insulated to the same standard as 240V wires. Using 240V-rated flex for 12V circuits near to 240V wiring is a good idea, but they must be clearly labelled.
It is for some but I've had that many shocks I ceased worrying about it many years ago. If you want to panic about something try drowning, that is 100% lethal.OMG….240 VAC is a lethal voltage and will kill. Do you really know better than the regs? I would suggest for safety you don’t tamper with what you don’t understand.
you can get Red/Black twin cable in all sizes you might want to use. so no, not cheaper, just lazierCheap, using 1.25mm2 mains cable will be cheaper than using 4 or 6mm2 auto cable.
I have seen them use both blue and brown for +12v in the same vehicle. Hymer was the last one I had this happen on.lovely idea. Except brown is used for +12V very often as well.
I needed some urgently earlier this month and paid over the odds for it. If you know a cheaper supplier I would be interesting for future reference.you can get Red/Black twin cable in all sizes you might want to use. so no, not cheaper, just lazier
Once when the water pump failed I bought a temporary replacement while in Italy. I had to wire it brown to blue, blue to brown. Never assume anything in a motorhome, always get out your meter and check.lovely idea. Except brown is used for +12V very often as well.
Yep, Reich pumps use brown for +ve and blue for - ve the opposite of Hymer.Once when the water pump failed I bought a temporary replacement while in Italy. I had to wire it brown to blue, blue to brown. Never assume anything in a motorhome, always get out your meter and check.
In my Hymer (2005) from memory. The cassette area had brown as + but behind the fridge it was blue as +. It cause a great deal of consternation as the pump I fitted for the water filter tap worked perfectly. But my SOG was blowing inwards. It wasn't until I rechecked the polarity that I found out the colours don't matter in a HymerYep, Reich pumps use brown for +ve and blue for - ve the opposite of Hymer.
When I cabled up my camper, I decided to use black as -ve and a selection of colours for +ve for identification for cable runs with multiple services (similar to car wiring and all-in-one looms like Sargent).Once when the water pump failed I bought a temporary replacement while in Italy. I had to wire it brown to blue, blue to brown. Never assume anything in a motorhome, always get out your meter and check.
I didn't mean using mains flex. Brown is the standard colour for negative 12v (chassis ground) in the DIN (German standard) automotive wiring colour which is by the same standard referred to as Terminal 31.This is why I hate seeing mains flex used on DC circuits. I don't understand why so many dealers use it when adding circuits such as Solar.
maybe you didn't. But dealers DO use mains flex for wiring DC circuits. I am talking about twin-core brown+blue cable, and occasionally you see 3-core flex used and the PE wire cut short. And german standard wiring colours are in the minority anyway. We don't all have Electroblocs or VWs.I didn't mean using mains flex. Brown is the standard colour for negative 12v (chassis ground) in the DIN (German standard) automotive wiring colour which is by the same standard referred to as Terminal 31.
