Whooshbang Door Seals Sticking
Kannon Fodda
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
The rubberised seals on the side sliding door on my PVC are sticking to the door paintwork internally. After a few days of non use the door can only be opened by pushing from inside to break the adhesion.
I could clean with say methylated spirits and then apply silicon spray, but would the silicon then simply acquire more gunge?
Any suggestions please?
I would Clean & polish the metalwork where the rubber seals touch, I would also clean the rubber seals and try applying some talcum powder/chalk or similar to the seal mating edges.
If you think about it, when rubber seals are new in their packaging, they do appear to have a light coating of powder on them.
Good luck, I am sure you will find an easy fix.
LES
Upvote 1
Autoglym do a Plastic and Rubber Care product that can be applied to door and window seals to help prevent sticking.
Upvote 2
Ali G’s suggestion is good and should work well with the following.
Spray WD-40 High Performance Silicone Lubricant onto the rubber surface and wipe it off with a lint free cloth. I would avoid microfiber cloths. Furniture polish is often silicone based but do check the can.
Some people swear by Vaseline, olive oil and grease while others are adamant that they will all react with compounds in the rubber and cause it to break down. In my view you should avoid using petroleum on natural rubber seals, as it can degrade them. You should also avoid using vinegar or any acid, on rubber seals, as it can cause the rubber to swell, crack, and degrade.
An alternative is a rubber conditioner. Some brands that make rubber conditioners include Sonax, Wurth, and Meguiars.
Another option I favour is French chalk (magnesium silicate) which is used by gymnasts and divers. It’s great for helping to get one's head through a dry-suit neck seal.
Upvote 2
Looks like elbow grease with a wax polish on the paintwork, and a proprietary cleaner for the seals (they are slightly sticky in places so somehow that needs to be cleaned) before a talk/chalk coating is the way forward.
Not wax polish. Try Paintseal Direct Waterless Wash (DryClean) on the frame. It should lift any rubber residue and will leave behind a fine siliconed surface.
We use Nextzett Gummi Pflege on all rubber seals on car & motorhome with no sticking so far (y)
Aerospace 303, apply to the rubber interface. You don't need a lot. Are you back home at home currently? If so I can pop round and drop a squirt on the seal for a trial for you, but can confirm I use it on all our door and window seals for the reason it stops them sticking, in my experience.
Mike.
I have same problem not helped by van being nose down on the drive. I have tried silicon spray, talc and würth sponge applicator rubber care. No joy yet. Now used to climbing through from cab and pushing from inside.
Try Olive Oil and you can stop eating your spinach! 🤔
Upvote 1
Stop waking up the neighbourhood and use the cab door?:unsure::whistle2::giggler::getmecoat:
Not that practical as the windscreen cover won't stretch enough to allow the cab doors opening.
Mike.
I'm at Sethorns at the moment.
Will have to google this and a few other named products to see what is what. :)
Hi Rob the best stuff is lip balm 😉
Easy / clean to apply and cheap as chips. Used to use it on all the double glazing rubbers to stop them sticking / perishing 👍
I'm not going to ask how you discovered that one :whatthe:
Terry LOVES his vehicle! 😄
I use a silicone spray and apply it to all the seals with a microfibre cloth. Seems to be plenty good.
Although I heard from a friend of a friend that Lizzie Arden creams of some variety are almost as good. Cheers Harry.
Johnson & Johnson phased out talc from their US baby powder products some years ago due to law suits arising from cancer cases. They continued to sell talc-based powder in countries where legal pressures were weaker. I think they intended to phase talc out eventually, in favour of a cornstarch-based formulation, in most jurisdictions.
If you do buy it it may be worth checking the ingredients to be sure what you are getting.
I use a Silicone Grease Lubricant I got via Amazon. It does not attack the Seal and is a simple wipe on using a microfibre cloth. I do this each winter before the layup to avoid the door sticking and tearing the seal. Its very easy to wipe back to very thin film. Give your door steel sealing area a clean as well.
