Any tips for silencing a whistling over-cab sunroof on our Bailey Advance? It plays a tune whenever we hit the dizzy heights of 60 mph (not often!).
Can you remember the part number of the new seal from prima ?If it's an advance I'm betting its out of warranty. You need to buy the new seal from Prima leisure. I had to do so for my Autograph
next time you’re in your motorhome could you put a photo of catch up please,sounds like a useful tipOur whistle is now significantly improved, thanks to a small piece of ‘grippy mesh’ stuff under each of the 5 catches, effectively tightening them a bit.
https://www.primaleisure.com/product/1300575 is what I bought for my Autograph, 5m worth.Can you remember the part number of the new seal from prima ?
Our alliance se 70-6 whistles above 55mph.
Cheers
Cheers Paul, I sent emails to Prima to try to get that info and no luck.https://www.primaleisure.com/product/1300575 is what I bought for my Autograph, 5m worth.
I think the "upgrade" part is basically thicker, but if you don't have the 2 side by side i guess theres no way to know :-(Cheers Paul, I sent emails to Prima to try to get that info and no luck.
Ours is a 2021 Alliance se 70-6, is there any way of knowing if this part is already fitted or the original version ?
I've just heard back from Prima that the 1300575 isn't compatible with our sunroof??https://www.primaleisure.com/product/1300575 is what I bought for my Autograph, 5m worth.
Have you joined any of the facebook bailey specific motorhome groups? should be more there that have had same problemI've just heard back from Prima that the 1300575 isn't compatible with our sunroof??
Having said that though, I've got no confidence in the customer support person I've been emailing.
1st reply sent by prima was a link to the full sunroof.
2nd reply from prima was for the sunroof surround at £400
I emailed back stating I only need the rubber seal and I believe it's part number 1300575.
They have just replied that the part 1300575 is not compatible with our motorhome.
So according to Prima I need a new surround at £400!
I'm not on Facebook, so no I havnt.Have you joined any of the facebook bailey specific motorhome groups? should be more there that have had same problem
