Which rivnut to attach solar panel to aluminium angle (1 Viewer)
Lizbiebrowne
413
508
Teesside
Hymer B654
Since 2019.
I've taken delivery of my solar panel, my aluminium angle is on order and I plan to use rivets to attach the two together.
So should I use aluminium rivnuts and aluminium bolts to hold the two together to avoid galvanic corrosion? Are aluminium bolts strong enough? Or should I use steel bolts or rivnuts or both?
Oct 21, 2021
101
411
New Zealand
Mutsubis fuso/canter
5 years
You would be better to use "plus nuts"
They have a larger internal grab area when compressed.
MisterB
6,707
15,444
Essex
Adria 670 SLT
I used M6 but then I also added some self tapping roofing bolts aswell, still holding string, though I do check them every now and again...
Nov 2, 2022
466
575
Gloucestershire, UK
Burstner Eliseo C602
Since 2016
Be aware that some solar panels have sides that are hollow, i.e. 2 layers of aluminium with a 2-3mm gap. You can easily crush and deform the sides.
Most panels come with mounting holes in the single skin base.
Dec 2, 2019
4,631
10,326
South Lincolnshire
Rapido 7065+
Broken most bits now
I used Tech Fast self drillers to attach the panels to our plastic mounts. The bigger problem is how you fix your aluminium brackets to the roof. I used Sikaflex and sealed Tech Fasts. No problems with any fixings after 4 years and 35k
Aug 26, 2022
343
671
North Cumbria.
Hobby Vantana
Since 2013
I used 8mm alloy rivets that were 18mm long with no issues from the double skinned panel frames. Heavy engineering , but why not!
The bolts to attach to the 50x50 alloy angle are stainless steel, again no problems during the 18 months that they have been on the roof. Final attachment was purely bonding.
L
Lizbiebrowne
413
508
Teesside
Hymer B654
Since 2019.
Too late, I've ordered the rivnut tool now.
I don't want to put any holes in my roof
I used M6 rivnutsView attachment 929510 and stainless button head cap screws.
That was my gut feeling - use aluminium rivnuts and stainless steel bolts. I don't live near the sea so I was not expecting corrosion to be an issue.
MisterB
6,707
15,444
Essex
Adria 670 SLT
I didn't ....I added the self tappers through the fixing frame NOT into the roof !!? I used the plastic corner and side mounts not aluminium angle ...
Lenny HB
55,872
163,024
On the coast in West Sussex
Carthago Compactline
I used M4 rivnuts I wanted M5 or M6 but out of stock of ones with the right panel thickness.
The side rails on my panels were double skinned the rivnuts pulled though and lock against the outer skin.
I used silicone grease as a barrier on the rivnuts and the washers when fitting the brackets, as I used stainless rivnuts.
Feb 27, 2011
15,196
80,284
UK
Self Build
Last time on a PVC I used stainless steel self tappers and copious quantities of Sika.
But back then I hadn't heard of rivnuts.
I will now use rivnuts to connect the solar panel to the aluminium angle. Probably still use self tappers to attach the angle to the van roof though.
Last one held up for 10 years and no sign of any corrosion when they were removed.
Feb 27, 2011
15,196
80,284
UK
Self Build
There is a mastic product called Duralac which is used to prevent galvanic corrosion in stainless bolts in aluminium rivnuts on boat spars.
Excellent product.
Tony
If you cover the stainless steel there is little if any opportunity for galvanic corrosion as I understand it.
Basically without water/moisture it cannot happen?
That is why I covered my install with Sika. Not sure it needs a product specifically designed for it?
Jan 25, 2024
136
160
North Norfolk, UK
Bailey Approach 745
since 2012
It’s to keep moisture out of the spaces between the ally and stainless, such as in the threads.
Avoids a cell which is what galvanic corrosion is all about.
Tony
Oct 18, 2019
55
89
North Yorkshire
AS Broadway EB
Since 2019
Duralac is the correct barrier product to use as Jabstatt says, however in reality your motorhome is likely to fall to pieces long before the stainless screws/ally rivnuts give way.
Jan 25, 2024
136
160
North Norfolk, UK
Bailey Approach 745
since 2012
It’s not about them failing.
It’s to make it easy/possible to dismantle.
Rivnuts are a great easy to use solution but if the bolt is corroded, the whole thing turns and, by definition, it’s usually inaccessible in a blind hole.
Ever owned a Landrover??
Tony
