Which recovery mats
Brassempouy, south west France
Hymer B878 SL
Since Feb 2020
Having a 5 ton tag axle van with front wheel drive I'm always wary of wet grass and what's beneath it. I've see others bogged down and the trouble involved in getting them free. We have hydraulic levellers so we can always lift the front end out of the muck, but which recovery mats to then put under the front wheels?
North Norfolk, UK
Bailey Approach 745
Google waffle boards!
I’ve four square ones for jacking and two long ones for the Defender.
Not cheap or light but fantastic.
Tony
Newcastle under Lyme
Hymer B544 A Class
The trouble with mats is they only get you a metre or so forward. That may be enough, but frequently not.
In a Fiat tag axle, I think I'd avoid all grass except in summer drout conditions.
Devon, UK
Hymer
Since 1984
Whichever mats you decide to buy, the trick is to park on them if you suspect you may be going to have trouble leaving. They'll spread the weight and give you a good start so then if you move off steadily and don't go back to retrieve the mats until your van front wheels are on terra firma you'll give yourself the best chance. Oh, and don't buy the floppy rubber ones as they're not much cop. You need the more rigid ones for weight spreading purposes.
Two on Tour
Elddis Autoquest 175
These are the only thing worth getting, I carry 4 of these sand ladders that have the top surface impregnated with grit for grip.
tonka
Cannock, Staffs
A class Burstner 800
Since 2000
I have these available. £20
25mm thick x 200 wide x 800 long..
BUT I think you may be to far away from Staffordshire..
(Yes, a subtle advert :whistle2: (y))
Hymer B544 A Class
Where would you put those when they're full of mud ?
tonka
Cannock, Staffs
Since 2000
Hi Tonka
we are in Stoke on Trent for Xmas, as my stepson lives there. Which part of Staffordshire are you?
Cannock . Right on the A5 just off junction 12 of M6. Xmas is a long way off so they may be gone by then as I have them on eBay and Facebook.
