Thanks but trying to move away from Chinese. Teltonika made in Lithuania.I have a different router, a Huawei B535 and i power this with one of these, the price seems to have gone up a lot since I bought mine last year.
2 IN 1 Step Down Converter DC 5-36V To 1.25-32V Buck Voltage Regulator LED +Case | eBay
Find many great new & used options and get the best deals for 2 IN 1 Step Down Converter DC 5-36V To 1.25-32V Buck Voltage Regulator LED +Case at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
I tapped into some 12v wires powering the TV aerial booster and fitted a small rocker switch.
Post #24 in the following thread.
It’ll handle 9-30 volts as a power source, no need for a regulator.
Avtex AMR985 Mobile Internet Solution. Anyone have experience of it?
At Shepton and looking at the above, 5g ready aerial, two unlocked sim ports at a good price. Anyone got one? https://avtex.co.uk/routerwww.motorhomefun.co.uk
There’s a few RUT950’s on eBay just now around the £140 area, unless you’re after something newer. I’ve found the 950 to be perfect for our needs. I was lucky enough to get ours for £85 off eBay, just needed the latest software update from Teltonika and away we went.Thanks but trying to move away from Chinese. Teltonika made in Lithuania.
That’s what mine came with as well as the 240v UK plug lead, so I just tapped into existing 12v wires. When buying a used one, the power cable needs to be included because it’s an odd plug.If you want to keep the 240v U.K. plugged step down transformer that Teltonika supply with their routers, (for home/static use maybe?), they also have available a bare ended cable with the power socket connector that can be spliced into any 9-30 Vdc source.
I was watching one the other day on eBay and was interested in it until I noticed the main case was the wrong way around (blue banner antenna side) so thought may it had a problem and been taken apart.There’s a few RUT950’s on eBay just now around the £140 area, unless you’re after something newer. I’ve found the 950 to be perfect for our needs. I was lucky enough to get ours for £85 off eBay, just needed the latest software update from Teltonika and away we went.
The older version has to be taken apart to put the sim in, very simple to do though. The newer one has the two top slots, like mine.I was watching one the other day on eBay and was interested in it until I noticed the main case was the wrong way around (blue banner antenna side) so thought may it had a problem and been taken apart.
Good product, yes but it’s not theirs. What you’re paying for is them putting together a package and the advice/support they can give if you’re not sure.Motorhome WiFi have always looked after us - when we get stuck - one phone call or email - so good product, great after sales service - nice people - get it cheaper buying from Amazon etc - but you are on your own.
Netgear M2 MR2100 comes out as good as you'll get i think, i have one and pleased with it.I want to buy a mifi unit for my new motorhome I think there’s Maxview and net gear is there anything else if anyone got one how do they perform
Do you use a UK sim or buy sim card in country you are visiting?Netgear M2 for me, though i do also use a motorhome wifi set up sometimes. the only downside i have with the m2 is when i try to tether it to an existing network (and not using the sim card) - thats when the motorhome wifi system comes into its own!
for roaming use via the sim ive never had an issue around different parts of France or the UK with the M2
Do you use an external aerial with it or is it fine without?Netgear M2 MR2100 comes out as good as you'll get i think, i have one and pleased with it.
I use a Huawei B535 with a Poynting antenna and I find it works well, can’t comment on using abroad but I can’t see why it wouldn’t work with a local sim.Has anyone used HUAWEI 4G Router LTE cat4 ? If so is it any good and would it work abroad using a local sim card form country visiting?
TIA
I have previously used a UK sim, but as things have changed, I may consider a local one. I had my M2 unlocked last year so that should help if necessary. I have used a roof mounted aerial but to be honest I didn't find any issues without it being connected to the roof mounted aerial.Do you use a UK sim or buy sim card in country you are visiting?
When in the Van it is connected to the roof mounted Antenna, i have it hard wired to a mounting plate in the vanDo you use an external aerial with it or is it fine without?
