Which is positive and negative?
It's the RUT955 which has twin antenna sockets. In hindsight it is a bit of overkill as it takes 2 sim cards which I don't need. They do other similar models for single sim cards which may be more suited to a typical MH installation.
But mine has worked well connected to a Poynting antenna.
I’m thinking about changing my Huawei B535 for a Teltonika rut950, also considering the 240 but not sure which would best.
I’ve just got to be brave and buy on, hopefully they would be relatively easy to set up for roaming, I’ve already got a Poynting antenna on the roof.
Thanks. I actually bought one of those but couldn’t figure out how to use it. The instructions (such as they were) were in German/Klingon/Hindi and there was a tiny diagram with some but not all parts numbered. In the end, I gave to another funster. 👍
They are fairly self explanatory, one pot adjusts the current limit the other one the output voltage. If you had looked at other listings a few of them have the instructions in English.
Things are always easy when you know.
All the ones I looked at were on ebay, but I think but you’re right, I should have checked the instructions were in English. What I really needed was a Dummy’s guide.
If I recall, somone posted up some instructions and a user‘s guide, about a day after I posted it off. The kindly funster recipient was gracious enough to offer its return but I declined and put it down to experience. I may buy another but as DBK stated, the router he uses accepts a range of voltages so for this project, it's probably not necessary.
Yip, easy when you know how.(y)
Just to help here are detailed instructions.
Open mouth
Insert (rubbery end)
Close mouth
Fa' asleep
(y):giggle:
pssssst Mrs Ingwe, don't think he's sussed us oot yet!:whew:
