I'd rather keep the length down and security up, but a good point!Or a bike trailer?
Yes. My Burstner Lyseo just needed air assist (£600 fitted) to the rear to take it from 3500 to 4250. Having air at the rear also will booster the suspension to take th weight of your motorbike. I have a electric moped in mine (80 kg) but also carry 2 cycles, chairs, table and all the other rubbish needed for touring several months at a time.Thanks guys. Helpful stuff for this newbie...So can 'most' low profile vans be 'upweighted' (wrong term I'm sure...) to more than 3500 or is it case by case?
"Up Plated or down plated" is the term. Case by case for sure as it often depends on what has been up plated before. Often it is rear air suspension and higher load rated tyres are enough to get an increase. SVTECH and another company I can't remember the name of specialise in this operation if you are happy to pay them.
I read what Vansflyer put and if it works for him then fair enough. But unless its evolved since - the C tourer was built to be lighter than the then C line, I believe they're on the Fiat chassis (not Alko) but with alko extensions. Imo 180kgs of motorcycle will be pushing the absolute limits on back axle and tyres you then add the other stuff like chairs tables, bbq, bicycles and I reckon its too much stress and may well affect the handling and braking. I also know the one funflair is talking about and the grief they had just getting a towbar to work.Jongood, Vansflyer seems to have it sorted with a C-Tourer (see above post) regarding the weight so could you poss explain what you mean? Thanks.
Fair point on some of the vans low payload I should have been clearer.Can't agree with that, even the Compactlines are difficult to run at 3500, I have a 6.67m compactline on order went for the 4250kg as I don't reckon it can be run legally at 3500. The E lines at 4500kg have a poor payload so do the Liner for Two unless on an Iveco. Also nearly every Carthago I've see comes of of the factory 130 kg overweight.
I understand your concern but it is just fine and has been for nearly 19k Miles and 4 years. VB rear semi air makes a great improvement and along with the higher rated tyres is needed for the van to be up-plated. I also got the front springs changed for better ones as the oem ones were woeful. I know when the bike is onboard vs not but at no time has the handling or braking been negatively affected even when we are full for a winter trip.I read what Vansflyer put and if it works for him then fair enough. But unless its evolved since - the C tourer was built to be lighter than the then C line, I believe they're on the Fiat chassis (not Alko) but with alko extensions. Imo 180kgs of motorcycle will be pushing the absolute limits on back axle and tyres you then add the other stuff like chairs tables, bbq, bicycles and I reckon its too much stress and may well affect the handling and braking. I also know the one funflair is talking about and the grief they had just getting a towbar to work.
If this is your first motorhome I would always advise buying used first to see if it does what you think it does and your needs are what you think they are. And maybe in this case either look at a lighter motorcycle or get a tag or twin axle.
Hth,
I mentioned chassis rails simply because I wouldn't want to be loading a reasonably heavy bike into the garage without some chassis support under the floor, maybe it's just me being exrta careful.I understand your concern but it is just fine and has been for nearly 19k Miles and 4 years. VB rear semi air makes a great improvement and along with the higher rated tyres is needed for the van to be up-plated. I also got the front springs changed for better ones as the oem ones were woeful. I know when the bike is onboard vs not but at no time has the handling or braking been negatively affected even when we are full for a winter trip.
The chassis rails needed for a tow bar fitting is a completely different issue than the garage payload. You need to reinforce the chassis for towing a car on some of the C-Tourers but not to use the garage payload they claim is available, if you have upgraded the suspension etc.
We are easily within our rear axle payload by 150-200kg when "full" so I sleep soundly that we have some payload for more wine in the garage if needed.
I trust (maybe foolishly) that SvTech and Carthago have done the maths correctly regarding the axle load and the garage loading capacity. As an aside I don't believe any manufacturers MIRO or empty weight figures.
Forgot to add previously, the 790 Duke is great for my Mrs, she is Kylie size and I am much larger at 110kg. Very comfy two up but I did change the rsu as the OEM wouldn't cope with me, her and the topbox loaded up. It would have cost more in chiropractic bills than the shock did. More room than the 390 we had before and much smoother being a twin, and if riding solo is a ruddy hoot to ride![]()
If your budget is in Carthago range, don’t overlook Frankia, they make some very impressive vehicles. Think SMC are main dealers….we had a good look at them at the NEC recently. Have you considered tag axle vehicles, as this would increase payload, although length too….Tvm Vansflyer and Enark. The Carthagos look very tasty. I've had my eye on a C-Tourer on Autotrader which I think will fit the bill perfectly. Research to do....
Still got mine, must have done 5000 miles now. My new girlfriend likes bikes so she rides itBurstner Elegance tag axle.
I have my 390 Duke in the garage permanently. I only use it ( very occasionally when it’s dry ) when I’m away in my van. Loads of payload ( just over 1t ) so no problem weight wise.
You will need a driving licence upgrade though.View attachment 794050View attachment 794052View attachment 794053View attachment 794054
