Which Awning???
Staffordshire
ADRIA MATRIX 600SL
1st timer since Jan 2023
Anybody recommend a good quality blow up awning, medium sized for a 2022 Adria motorhome ! Just so many out there, my ideal budget would be up to the £300 mark 🤷‍♂️ Regards for any help . . .
Problem I'm finding is with the height, as rear is 263cm, and the front 247cm 🤷‍♂️ So limited kn choice as a lot of awnings on offer are for caravans at 250cm max 🙈 Might go 390cm width now as Thule is 400cm be a big space as got 2 x grand kids on way in July, and at least 1 x dog so could set up 2 x tables, or double bubble to eat in there. Moho not really big enough to entertain, as also like a party occasionally, get some fairy lights up and sound system be great space.
Do any idea's would be gratefully accepte, thinking defo blow up, with fixed to Thule as not bothered about drive away, me and my pals have a Scooter each, or a couple have tow cars.
Hi I have a Outdoor Revolution T4 Movelite Highline with Footprint ground sheet and Vango high capacity pump Bought August 2020 used 3 times so as new Also matching 2 berth inner sleeping tent bought a year later and never used £350 for the lot Delivered Original receipts available
Don't think that will fit my Adria Matrix as it's 263cm from bottom of Thule to ground 🤷‍♂️ T4 more for Transporters if low or mid line only go up to 255cm I think, Yes???
As most people buy an awning, use it a couple of times and then put in in the garden shed for 3 years before they sell it, there is usually a load of "Only three years old, only used twice" awnings of all sorts available in the classified section.
What most motorhomes end up with is a Quest Screen House (4 or 6) which can be put up, single handed like an umbrella. It also weighs a lot less and is considerably smaller in the bag.
Something you need to consider with the Screen House is the length when packed away. It is around 6' long so you need to be able to accommodate that length wherever you intend carrying it.
This is not to knock the Screen Houses by any means, just something to be aware of. I had a Quest Screenhouse 6 (which when packed was actually taller than the 4.5M x 3M full Heavy Duty Marquee I used to take to shows!) and I loved it :).
I sold the Screenhouse 6 when I decided to get the Screenhouse 4+4 model instead.
This is the Highline version I had it originally for my Burstner Ixeo Time 690G 55 edition and then Mobilvetta k-yacht 85 it fitted both It also has the Omnistor/Fiamna interface kit It fits motorhomes 255-305cm so perfect for yours
I've got a 2021 Outdoor Revolution T2 highline which was erected once in the garden to see how it was done, then put away in the garage.
That fits my Broadway and goes from 255cm to 305cm. If that's any good for you make me a reasonable offer by pm
