Shrimp
Seems fine but we only use it for charging things like Dyson when we are travelling, it’s not a big powerful inverter,
Is that a major undertaking, Lenny? At the moment, our inverter is just stand-alone, in the garage next to the LiFePO4 and I plug into it direct, or use a fused 13A extension socket. I often wonder how easily it could be linked to the 230V sockets in the van, or whether it’s worth the hassle.Rewired the sockets so they can be switched between incoming mains or inverter.
We are having an upgrade at the moment and have gone for wiring it to the existing sockets. It sounded a faff to have to plug in direct to it?Is that a major undertaking, Lenny? At the moment, our inverter is just stand-alone, in the garage next to the LiFePO4 and I plug into it direct, or use a fused 13A extension socket. I often wonder how easily it could be linked to the 230V sockets in the van, or whether it’s worth the hassle.
Fairly easy if you are confident with electrical wiring.Is that a major undertaking, Lenny? At the moment, our inverter is just stand-alone, in the garage next to the LiFePO4 and I plug into it direct, or use a fused 13A extension socket. I often wonder how easily it could be linked to the 230V sockets in the van, or whether it’s worth the hassle.
Hi Lenny what about the victron multiplus, differnet bit of kit, but I take it that has the changeover switch is built in?Fairly easy if you are confident with electrical wiring.
Need to check your sockets are on a separate circuit if not it's best to rewire so that the sockets are separate as you don't want the fridge, charger & heating running from the inverter, should be able to do it at the consumer unit.
If your inverter has neutral bonded to earth it's best to fit an RCBO on the inverter output then fit a generator changeover switch so you can switch the sockets between incoming mains and the inverter.
Like this.
Yep a great bit of kit I've just fitted a Multiplus 3000 to my van, awsome 120 amp charger great for charging the Lithiums.Hi Lenny what about the victron multiplus, differnet bit of kit, but I take it that has the changeover switch is built in?
