Tesco’s 5 ltrs spring water £1.20 and the container will last you 3 to 6 months so you can refill it on your travels.
I topped ours up at garages and services.
Got two of those, it's what we take our drinking water in and they fit snug in the pull out cupboardTesco’s 5 ltrs spring water £1.20 and the container will last you 3 to 6 months so you can refill it on your travels.
Doesn't the Almighty supply the water in the first place?And they shouldn’t, or at least, not without permission. Churches have to pay for the water they use. Filling up a motor home tank from a cemetery tap isn’t really on.
I thought helping the needy, and all that malarkey, was a churchy thing to do.And they shouldn’t, or at least, not without permission. Churches have to pay for the water they use. Filling up a motor home tank from a cemetery tap isn’t really on.
Ewart of thunder boltsI thought helping the needy, and all that malarkey, was a churchy thing to do.
Considering that they operate their business "tax free" helping out a thirsty soul with less than pennies worth of water wouldn't noticeably effect the bottom line.
I carry 10ltrs drinking water only keeping the running weight down 10lb per gallon. It sufficient till I get to site though only use for washing etc still use 10ltr for drinks
Council run cemeteries, you will have paid for the water in your council taxDoesn't the Almighty supply the water in the first place?
I believe Milton can cause harm to boilers.I love the mixing of old measures and new, and the mental mathematics required to convert.
1 liter of FW = 1 KG
On more serious note how often do MH owners sterilise their FW tanks on average, (especially after its been empty for a while) and do you use a product such as Milton tablets to do it.
as a FYII carry 10ltrs drinking water only keeping the running weight down 10lb per gallon. It sufficient till I get to site though only use for washing etc still use 10ltr for drinks
That's nothing!I love the mixing of old measures and new, and the mental mathematics required to convert.
YesDoesn't the Almighty supply the water in the first place?
and never load to the upper Plimsoll line unless you know what seas are going to be sailed in?That's nothing!
I worked for 45 years in the maritime business.
The standard mixture of measurements are:
Metric (Usually for lengths and widths)
Feet and inches for drafts
Cubic feet for volume
Metric tonnes per cubic yard for stowage
Liquid volume measured in American Barrels
Specific gravity of oil measured in Barrels at Fahrenheit
Deadweight measured in Metric Tonnes
Lightweight measured in Long Tons
Gross and Nett tonnage measured in Medieval wine Tuns, except for the Panama Canal which measured in American Short tons and the Suez Canal which measured in Metric Tonnes.
Just to cap it all the conversion figures between all this were standardised well before pocket calculators or computers, at 3.2802 for meters/feet and 35.315 for cubic m/ft, which causes small discrepancies on every cargo for those not using maritime software.
About a two decades ago I eventually had to set up a 45 minute lecture with slides that I used to repeat at least 4-5 times a year to explain to new young people in the business what all these measurement mean.
A few years back I met one of the people I had explained all this to back in the 90's, and he told me he had never forgotten my story about the English King that introduced the medieval wine tuns measurement that is still used to this day.
Bottom line is it means I have no problem with the mental arithmetic to convert between systems
I am
Read your post and thought "Now there's a person who has copy of Norries Tables on his shelf somewhere" (ha ha)
I am still at sea, and the conversions are still done, except now most every vessel I see drafts are in meters and cms
We load fuel in cubic meters however the Saudis still want that converted to yankee barrels.
Most capacity measurements (and stability calcs) are now metric and the old stuff of yards inches gallons etc has been dropped to a historical footnote.
Of course the yanks have hung onto their old measurements and their ridiculous System B buoyage,
Your ability to convert quickly and leap between imperial and metric (and the other malarkey) is becoming rarer to encounter.
That said we still carry Norries (just in case)![]()
Yep but there are all busy,,people are dying to get in thereCemetery they have water taps.
Yeah but ts not a grave offence though is itAnd they shouldn’t, or at least, not without permission. Churches have to pay for the water they use. Filling up a motor home tank from a cemetery tap isn’t really on.
Specialist vessels involved in diving, pipe lay, heavy lift (up to 2300 tons) and ROV usually for the oil and gas industry but done some work in wind farms as well.What ships are you on ? VLCC's ?
There was me thinking the DP4 ships stayed on station using the google maps feature on their smart phones!Specialist vessels involved in diving, pipe lay, heavy lift (up to 2300 tons) and ROV usually for the oil and gas industry but done some work in wind farms as well.
I sail as Senior Dynamic Positioning Officer - C/O
DP4 is new one on me and I wouldn't be surprised if they were run by an app if they existed but DP only goes up to 3 and its about the level of redundancy.There was me thinking the DP4 ships stayed on station using the google maps feature on their smart phones
DP1 hasn't got any (ie if something fails you are out of DP)
DP2 has worse case failure default of at least 50% of everything running
DP3 basically has 100% basically by it having two separate engine rooms usually found on semi dub rigs and drill ships but other vessels do have it
Ours is DP2 and with it having 3 azimuths forward and three aft (and is barge shape as opposed to a ship shape) with a total output of 24,000 HP our foot print in current conditions (2.5 meter seas 28knots of wind on the bow 1 knot of current on the stb 1/4) is 0.6 of a meter.
No idea,What's this got to do with where OP gets his water
Brought up imperial, but do understand the intricacies of metric FYIas a FYI
1 Litre weighs 1 Kilo (exactly)
(or 2.2lbs in old money)
Edit: I see others have pointed out the same calculation!
