Where are my 35 watts going ? (2 Viewers)
Oct 10, 2023
26
33
Valencia, Spain
Rapido 9648DF
I tried today to plug my EHU directly into my Ecoflow 700w battery. Everything worked great. I was surprised to see that my fridge pulled 200w when filling, so the Ecoflow would only power me for about 3 hours. Anyway, that just by-the-by.
Anyhow, with everything switched off, including my control panel, it was still shoving 34 watts into the motorhome. I checked that everything was unplugged, no lights, no 12v , nothing on at all.....so i don't understand that. The MH has recently been on EHU for a week outside my house so every battery should be full, plus its very very sunny and i have a 200w panel on the roof. The only thing that i can't turn off (don't know how) is my solar controller, but f that is being fed by solar, surely it can't be using 35 watts independently?
Any thoughts where my 35 watts are going ? I need every one i can get !
meanders
Funster - Life Member
2,648
8,613
Ipswich, Suffolk
C class
Since 2004
In probability order:
Battery still charging even though reporting topped up?
Calibration error on the meter?
Next door have hooked up to your van and using your power?
Hole under the battery box so the watts are falling through it? šŸ˜³
8,699
45,074
Worcestershire
Bailey Adamo 75-4t
March 2018
Watts are lighter than air so probably boiling off the battery.šŸ¤”
5,522
10,322
Birmingham, UK
A-Class
Random light is on somewhere. Cooker is my favourite. But lockers sometimes have lights.
Or you have a battery master?
Or the head unit?
Tombola
4,862
15,784
Merseyside
Rapido 8094DF
Since 2004
Drain to starter battery
12v switched on in van so USB lights, control panel draw etc etc.
Have u left the bathroom light on again.. ;)
Lenny HB
53,673
150,885
On the coast in West Sussex
Hymer B678 DL
The battery charger even if the batteries are charged will still take some current, 35 watts is only 146ma (0.146 amps) at mains voltage, I would have expected a much bigger draw from the charger than that.
J
Oct 10, 2023
26
33
Valencia, Spain
Rapido 9648DF
Are you plugging the van into the 230v socket on the Ecoflow? You're probably losing a fair chunk of those watts just through it's own internal inverter.
yes, using the ecoflow as some kind of EHU. Good call. Ill try and plug something else into 230v the Ecoflow - of a known wattage - and see if it draws more than expected.
7,290
11,784
West Sussex
Carthago Compactline
Since 2003
I agree, if the Ecoflow is outputting 230V it will be running an internal inverter and even if it is outputting 12V it will probably be running a converter because the battery is likely to be 25V not 12V.
696
1,474
Bailey Alliance 66-2
48V inside most ecoflow units (needed to support the faster charges they offer), and agree, it's probably the charger needing the mcb tripping.
On our ecoflow (delta2) we've measured inverter losses at ~ 10W, it uses about 20W to run the TV... but still worth using the Delta2 for that, as we can just plug the solar in and get > 30W in most cases, so the TV use is "free" watts.
The neat thing about the ecoflow (and the allpowers 288w one we have) is both support turning on/off the inverter remotely, so we can turn the inverter on/off using phone and turn the TV on/off after that...
Clive Mott
Nov 12, 2012
284
468
New Milton
Concorde Charisma
Since 1972
Items I have seen previously taking electrical power discreetly include :-
Alarm system, many aftermarket systems are quite greedy.
A Tracker which is effectively a mobile phone with GPS running.
Reversing camera where the monitor in the cab has an ON OFF switch but the camera at the back is powered all the time.
Interior light in the wardrobe (Our Hymer has two)
30
55
Don't yet own one
Newbie
My dashcam is quite capable of flattening our starter battery. Don't know what its power consumption actually is, but as originally set up by the installer, it only took about 10 days!
Fortunately I was able to change the settings of the thing so it shuts down at 12.4V rather than the much lower voltage originally set.
87
67
Researching which type.
Future newbie from caravanning for 44 years
Are the fresh and waste water tank heaters on for they are too easy to knock on in our vehicle.
753
510
Hull
Autotrail 634
Since 2006
Is it still pulling 35 watts when you unplug the motorhome from the power pack?
