I bought them privately from a fella who was doing a van conversion....then changed his mind. I saved quite a bit too but I had to travel quite far to collect them.Can i ask whee did you source the wheels from & at what cost?
Karl
Karl
I see this a lot and I don't think it's correct. Surely it depends on what size tyres you fit? You can get bigger rims, provided you get a tyre with a lower profile sidewall. If you end up with the same overall diameter (to within a couple of percent), it won't make a difference.I doubt you can swap from 15 to 16.
Speedo will not read correct for starters.
Clearance on suspension may also be an issue.
Andy
I don't think fealets have parts books anymore and if you can't give the number on the parts counter the reg no he won't know what your talking aboutSome alloys use same nuts or bolts as steel , and not all alloys use same nuts or bolts as other alloys
safest answer is to visit dealer and look in parts book to see part numbers for the different options .
