DuxDeluxe
Of course. Ducks have built in strainers in their beaksLeaf tea I hope rather than tea bags![]()
yep... had one by the side of the bed, but the noise of the kettle boiling woke you up before the alarm went offI do like a Goblin teasmaid......![]()
Hi IanWe have a variant and it gets put in the van when go away. I mean, why slum it when it comes to coffee?
Ian
Hi Ian
I'm keen to hear your views of it
I thought it was in readiness for injecting the 'bleach cure' that DT has been promoting?Did they come from Ann Summers?![]()
Not the same now. Our Lavazza machine uses compostable capsules which go out with the compostable kitchen waste that our council collect every week. All wrapped in a compostable bag made from corn starch, not plastic.These are great espresso machines save a capsule and save the planet (I know I will get flamed for this)
The Guy who invented the capsule machine, now regrets having done so as it is just something else like plastic bags using a resource that doesn't need to be used.
Just buy loose coffee and either of the above and make yourself a great cup of coffee, or if you really really want that expresso when you are away why not buy a proper espresso machine. A budget machine such as the Gaggia Classic or splash out on a Rocket.
You may not be able to display your machine behind sliding glass doors but if you are environmentally conscious save a capsule and just use loose coffee (its cheaper too).
Lavazza here too. Really good coffee for a capsule and compostable. Caffeine hit and save the planet in one cup.Not the same now. Our Lavazza machine uses compostable capsules which go out with the compostable kitchen waste that our council collect every week. All wrapped in a compostable bag made from corn starch, not plastic.
Having said that I use a Mocha pot (see post #9) when we are in the motorhome. Still use Lavazza coffee in it, as got to like it a few years ago when we took the motorhome to Italy.
I installed a Nespresso virtuoso. This model was identical to that supplied by Carthago. Carthago charging about £250 bought ours for about £70 from John Lewis. If you go down the line if putting in said machine you will probably find that the socket high up in the back is still continental socket as it’s near impossible to get your arm up to change to uk set up. Simply just use a continual converter plug then plug in machineI was wondering if anyone knew which model Krupps coffee machine Carthago supply as standard with a Chiq C-Line? Most seem too big to fit in the slidy thing.
... no hint of the taste of coffeeBest stick to instant coffee....... no mess no fuss![]()
Better still put a continental plug on the flex. Many adaptor plugs have low watt limits and the electrical draw of a coffee machine might cause overheating and potentially a fire.I installed a Nespresso virtuoso. This model was identical to that supplied by Carthago. Carthago charging about £250 bought ours for about £70 from John Lewis. If you go down the line if putting in said machine you will probably find that the socket high up in the back is still continental socket as it’s near impossible to get your arm up to change to uk set up. Simply just use a continual converter plug then plug in machine
Yuk! Can’t stand instant coffee! lolWhat's wrong with a jar of Nescafe?
