what is my gross weight
Jul 22, 2020
333
674
Newent, UK
Etrusco T6900
changing a load of things again
there is a load of numbers on two plates, i am sure i will be told what it means
on the Auto trail 3500 and 4750
on the original 3650 to 6150
just checking my log book ,,,,,,,,,,,,,when i find it
Blly
Lenny is correct but that's not the whole story as the only way to know if you are not overloaded either in total or on each axle is to get your MH weighed including each axle individually - it's possible to be below your 3500kg limit but still be overweight on an axle (often the rear one).
Blly
Since the original plate shows gross permitted weight of 3650 the Autotrail plate has been downrated to 3500 presumably to allow marketing to any driver who has not got a C1 licence for over that weight.
Therefore if you needed to it would probably be easy to have it uplated again to 3650, if you have the C1 licence.
is this much of a job?
You need an engineers report which you can get from SV Tech they charge £312 or Van Weight Engineering only £180 from them, you fill out a form & send photos of your plates & tyres they will send you the new plate & report and then you apply to DVLA, you will also get a refund of your VED difference it's only £165 over 3500kg.
You should be able to go to 3850kg without any mods.
When we upgraded our 2013 Autotrail Tracker from 3650 to 3850 kg had to put bigger tyres on and rear air suspension.🤔
Had to you don’t have a lot of space forward to store anything and even after that couldn’t fit a towbar and leave enough capacity for a car trailer so bought a LHD Hymer👍😊
