- Oct 6, 2021
- 574
- 938
- PVC
Government website:Anyone know of a weighbridge near Portsmouth please?
https://www.gov.uk/find-weighbridge
VX man, already looked at those. Would probably go for the one with compressor and individual controls, a fair bit more costly but gives more control. Happy Jack.
There is one just off the Chichester bypass if thats close enough for you I'll find out who it is, a mate had his weighed there recently.Anyone know of a weighbridge near Portsmouth please?
Sorry Lenny, didn't notice the one you are talking about is for doon sooth.
Great, thanks that will be close enough, the one off Eastern Road Portsmouth and Havant, only do total weight, which is not much help as I also want to see front and back for tyre pressures.There is one just off the Chichester bypass if thats close enough for you I'll find out who it is, a mate had his weighed there recently.
Andy, is the one at Wingate flat ?There is one at Wingate you weigh the front and then the back and work out your total weight from their.
Andy, do you mean the Wingate near Peterlee and what is the facilty called also is it flat.There is one at Wingate you weigh the front and then the back and work out your total weight from their.
Fail to understand the significance of a ramp.Andy B, is the one at Wingate without a ramp ?
Here you are and it's a flat one.Great, thanks that will be close enough, the one off Eastern Road Portsmouth and Havant, only do total weight, which is not much help as I also want to see front and back for tyre pressures.
You can't measure axle weights accurately if it has a ramp as the van needs to be level.Fail to understand the significance of a ramp.
Jobla
Agreed, the one I went to yesterday was flatYou can't measure axle weights accurately if it has a ramp as the van needs to be level.
Thank you, will give it a go when loaded for our French trip in 2 weeks.
Yes Jobla. Understand that. It's ok to get max weight of whole van but doing the axles involvea part way on each time which alters the c of g. I'm not 100% sure it would make a huge difference but the readings would not be wholly accurate.The weighbridge in Gateshead is raised to accommodate the weighing mechanism. The vehicle is weighed in a fully horizontal position. One only drives up the ramp onto the bridge.
Jobla
Just to clarify. I take my van and I am provided with a cert showing rear axle,front axle and total weight. There are 2 weighbridges. You drive on first one for total weight then drive forward so rear wheels are on one and front wheels are on the other. Operator then takes individual axle weights. As I said previously the shallow ramp is just a means of getting onto the weighbridge. I would trust these readings before any taken in scrapyards and the like.Yes Jobla. Understand that. It's ok to get max weight of whole van but doing the axles involvea part way on each time which alters the c of g. I'm not 100% sure it would make a huge difference but the readings would not be wholly accurate.
Happy Jack.
Hi Jobla. Didn't realise there were 2 weigh-plates.Just to clarify. I take my van and I am provided with a cert showing rear axle,front axle and total weight. There are 2 weighbridges. You drive on first one for total weight then drive forward so rear wheels are on one and front wheels are on the other. Operator then takes individual axle weights. As I said previously the shallow ramp is just a means of getting onto the weighbridge. I would trust these readings before any taken in scrapyards and the like.
Jobla
