Water Tank ; How much when travelling between stops
Lincolnshire, UK/ Torre del mar ES
Autotrail Chieftain
Since 1983 motorhoming ,got the bug in a T2 in 76.
Hello ,just a straw poll type question
How much water do you carry when driving ?
50% or more
Just a little (to save fuel consumption.)
On a recent (sept) big carp fishing trip to central france i carried around 30 litres driving from caen to the venue ,my unit responded with almost a 5mpg bonus over a full water tank .
We’ll Mark, it’s the one thing that I could kick myself for, for not adding it to the options list🤦‍♂️ They are not exactly a light piece of equipment are they and I was thinking about payload at the time and trying to weigh (no pun intended) it all up. My bad. 😬
Should be a standard fit Steve as I would think trying to stop 7.5t in a hurry with the disc brake’s fitted is a bit hairy
we use about 40L per day..
I know that because when we refill using a 10L water carrier it's generally four trips to bourne to fill up
also from tugger days when a 45L Aquaroll lasted about a day ..
At least two showers , sometime four a day..and we don't skimp.. that's what it's for.. not going back to the 'good ol' camping days' of basin and flannel .. lol
I usually travel with a full water tank, 120lts, it seems to make no difference to my MPG the only problem is stopping distance.
Always a full tank of fresh (300litres) and empty grey. The less trips to fill up the better as I have better things to do when I'm on holiday 👍. The tank will last about a week give or take. If a little careful can get 10days before refills but we don't usually scrimp on water.
Upvote 1
I used to try to make sure that we had about 3/4 of a tank (75 litres) most of the time. I didn't worry too much about the impact on mpg, then I read something (on here I think) about modern water tanks not having baffles to prevent excessive sloshing about and not being robust enough to handle all the movement from the water. I started to limit myself to 20-40 litres.
I was grateful for the tip as I was running out of things to be paranoid about, (added it to: Lithium going on fire, LPG being phased out, being overweight, needing additional locks, cam belt going, leaving the hook-up cable attached, getting fined in Portugal, leaving roof light open, mirror guards being insufficiently robust, having insurance refused because of a sticker, accidentally coiling up my hook up cable or worst of all parking incorrectly on a CAMC site.
I think there will be more sloshing from a small amount than full tank which cant really slosh
don't know where you read that, but it sounds like fake news
At least you don’t have to worry about reverse polarity on the EHU post 👍👍
Full, plus up to 80 litres in the back, empty grey.
We like to park up when and wherever we want so lots of fresh is a winner.
As I’ve said lots of times when the same question is asked, you need to ready for the next zombie apocalypse 🧟‍♀️🧟🧟‍♂️ 🧟‍♀️ 🧟
I think there will be more sloshing from a small amount than full ..
I suspect you're right, when pondering it I decided there must be a sweet spot between more sloshing/less mass moving about.
Normally 100L for us. 👍
I always forget to fill when we arrive somewhere, or I am more concerned with bagging a spot so we tend to travel over 75%, if there is not much in i.e less than 50% the theory is that it would slosh about too much in the tank and wouldn't be good for the fixings etc.
Probably about 50% so 50 - 60 litres, Unless .... we are heading out of France on the last 24 hours of a trip. Then we drop to the bare minimum and replace the water weight with bottles of wine.
You and me both Martin👍
If I know I can fill up with fresh water where I'm going I travel with an empty tank. A cubic metre of water weighs a metric tonne. So if you're carrying 100 litres it weighs 100kg. Surely that must make a significant difference to fuel consumption?
Never more than 25%
We only fill to 50% on shower days and hopefully near a grey tank drian so we can empty it immediately after the showers.
We always stay off grid but Park4night will always find a water stop when you need one
Full always as we don't use sites. Plus I carry 6 x 5litre water bottles inside the van for tea & coffee & to use in the tank in the event it gets too low.
Always full fresh and empty grey if possible. If I could gain 5mpg by losing half the fresh water then I'd travel with no fresh water and a nearly empty diesel tank to get a 15mpg improvement.
I'd do the same except I'd forgo the extra mpg for upping the speedI'm travelling at:LOL:
Figures of 30/40lt p.d. or 300lt p w. blow my mind. We use 10-12lt p.d. for two of us including a shower each.
same here.(y)
Many factors can cause varying fuel consumption, for example a stiff breeze in the wrong direction can have a big effect on an aerodynamically pessimised structure like a motorhome.
As for water, it depends. If it's a long driving day, at least 50% if I'm not sure if water will be available. 25% if it's probably available. If the next stop is not very far, less than 50 miles, then 100% if I'm not sure if water will be available. 25% if it's probably available.
50% or more
Full tank, got plenty of payload.
Always like to fill the fresh to the brim and empty the grey and toilet cassette before we set off. Then we're ready for anything - free parkup / wilding / broken tap at an aire, etc.
On our van the weight of a tankfull of fresh water is around 1.75% of total vehicle weight. Any detrimental effect on MPG is so negligible as to be immeasurable. Certainly it's not going to be in the region of a 5mpg (approx 15%) improvement by ditching it.
Fresh water - always full (110lt)
Grey and Black always as empty as possible.
A fuel consumption increase of 1 or 2 mpg really doesnt bother me. Running out of fresh water would, especially as we very very rarely grace a campsite with our presence. And with our van at 4250kg, payload isn't an issue.
