Water Pump (1 Viewer)
Sep 10, 2017
427
964
The water pump on my 18 plate Campscout Revolution has just packed up.
it was working and then quickly got slower and stopped in the space of 20 seconds.
Does anyone know what pump is used and where to get one?
Jul 12, 2013
3,889
5,295
The City of Henlow
Adria Supreme
Since 1980
There are basically 2 types of pumps, the type fitted outside the water tank and those fitted inside. The next move would be to find out how many gallons per minute (or litres) they pump. The most popular are Sure and Whale but there are many others available.
May 9, 2018
95
82
South Oxon
Globecar Campscout
Unfortunately it's quite a common issue reported on Globie forums. Often it seems to be caused by the pump being activated when the tank is empty or by the bathroom tap being left open but the lever on the shower head being closed. (Each tap has a micro switch which runs the pump when the tap is opened).
This is the pump I'm carrying as a spare.
Amazon product ASIN B0013E105G
The pump is within the freshwater tank. I've not yet had to replace mine though so hope it's the right one!
427
964
I will have a look in the tank when i drain it tomorrow and see what i need, I will probably get two so I have a spare for the future.
32,759
66,905
It's probably the same as the one in my post:
427
964
It’s the same one.
I just ordered two @ £15 each
Hopefully they are easy to fit.
[/QUOTE]
Well it's easy to fit unless you break the one way valve getting it off.
now waiting for a new one way valve :mad:
