- Feb 18, 2009
- 584
- 260
- Malibu T410
- Since August 2008
We have a 'Lilie Shurflo Soft' water pump LS H42 - works fine but fairly noisy which is not the problem.
Whenever we move and then park up -when we next use any tap for the first time the pump then has to run for a few minutes to fill the system again - makes no difference if we leave the water pump swith on or off. Once the system is used after that -its fine - no noise/pump running when not in use - no sign of leaks.
Had a look at the on - line manual and can't see anything in the trouble shooting section thats related.
I would have thought the system should stay full? previous vans haven't done this - so guessing something is not right? Any ideas?
