Water pump running won't turn off.
Sep 15, 2009
2,032
4,873
Sussex coast
Lowline
learning
As title water pump running just fired up on its own. But is pushing water into wc.
Luckily I found this before bowl overfilled.
I have turned pump off on panel for time being any ideas
Hi again its a thetford loo taking flush water from main tank.
Now I've looked and the relay was showing signs of corrosion. Unplug it pump Dosnt run.
Son im assuming its relay. As I replaced this some years back. I went to Halfrauds and thought I matched it but the new one. Dosnt do anything.
So I know need to find a partnumber as to get correct part
If it's an automotive type relay, the blade terminals are usually numbered next to each terminal and some also have a schematic of the relay circuit.
Might be worth having a look to see if the terminal layout is the same for the new and the old relay.
