klaatu
The water pump on our six month old Globecar Summit 640 has started to occasionally continue to run after a tap has been closed, either the kitchen tap or bathroom tap. This has started happening approximately once a day.
The pump is operated by microswitches rather than by pressure, and is submersed in the water tank. As it happens with both taps, I’m pretty sure it’s not a microswitch problem (but I accept that it might be). I’m not sure what make of pump it is.
Turning the tap on and off for a couple of minutes eventually causes the pump to stop. As an experiment, today I tried doing nothing to see if it would stop on its own, but it didn’t after several minutes.
Turning the water pump off at the control panel doesn’t stop the pump when this issue occurs, but it does normally stop the pump operating when the taps are opened at other times.
Any suggestions as to what might be causing this?
