Water pressure dropping (1 Viewer)
Mar 1, 2021
113
72
Bury st edmunds , suffolk
N+b arto
Newbie
If I do the usual fill water then open taps till air has gone and get a good flow thats great but after a while I have to do the taps again . And then another 2 hours again is there a non return valve thats letting me down or a pump issue
Arto 69 2007
Apr 27, 2016
6,980
8,160
Manchester
A class Hymer
Since the 80s
I'm guessing the pump is a submersible, that goes inside the water tank. They have a non-return valve, either built into the pump or inline with it. They are rotary pumps, and the water can back-flow if the non-return valve fails. Obviously you could replace the complete pump and valve, but an alternative is to cut the pipe somewhere above the pump, and fit a non-return valve. Either inside the tank in the short pipe above the pump, or just outside the tank.
There's different fittings - push-fit, barbed, etc depending on what kind of piping. Some of them push directly onto a spigot on the pump.
W
Mar 1, 2021
113
72
N+b arto
Newbie
The pump has great preasure but as you say no seal i could add a non return valve
But if the pump has a fault that could mean other parts of the pump may be worn aswell its a 2007 arto so I think the quality of van deserves a new pump any ideas where I can get a new one from please I know if i call neismann that will be £400 lol its a plastic pump
Apr 27, 2016
6,980
8,160
Manchester
A class Hymer
Since the 80s
Not familiar with NB fittings, but you could look at the pump to find the make and model, they are usually available in caravan/motorhome accessory/parts shops. Leisure Shops Direct or O'Leary's for example. The pump will have a pressure (eg 1.5 bar) and a flow rate (eg 19 litres/minute). Anything that matches these specs will be OK. Provided it fits in the tank hole, of course. Some have built-in one-way valves, some need the valve added.
