- Dec 24, 2014
- 10,254
- 55,063
- Compass Navigator
- Ever since lighting was by Calor gas.
I just nip down to the manshed and pop mine in the ultrasonic motorbike parts cleaner.
That will set tinnitus offI just nip down to the manshed and pop mine in the ultrasonic motorbike parts cleaner.
Nah, I take 'em out first!That will set tinnitus off![]()
Mine is on charge too, arrived yesterday. Box not sealed and had been opened but all the bits inside in sealed plastic still. I am going to try it in shower first as recommended by some reviewers who found it took a little while to get the hang of not spraying it everywhere!Its arrived and on charge, I'm impressed that the batteries are replaceable look like two AA or AAA, unlike toohbrushes they seem to be disposable when the batteries go
They must have changed it or you got a different one. Mine has rechargable batteries that are not replaceable which is why I am surprised it still works after all these years.Its arrived and on charge, I'm impressed that the batteries are replaceable look like two AA or AAA, unlike toohbrushes they seem to be disposable when the batteries go
Me too!I’ve ordered one !
Why did you have a light bulb in your mouth that you turned off?I took out a light bulb in my first week. Took it out of my mouth before turning off and it shot water through the bathroom door and hit an incandescent light bulb fitting and the bulb popped and tripped the breaker. Didn't have make me jump. You do get the technique pretty quick though.
All LED light bulbs these days so not that much of a risk![]()
That can happen occasionally. I found this when I had minor gum infections. These infections clear themselves up on their own and you generally don't notice them. But the agitation of the pick can cause you to notice them.I may have used it a bit too much for first time, my gums feel a little sore. !
Yes, I like Corsydol too but at present only have Listerine as where I shopped had it on offer, but it is not as good. I have no problems - I don’t think - but just aware that have not seen dentist this year and not likely to. Would normally have descale and clean twice a year. Plaque build-up is more of a problem but I know that the water flosser will not remove this. The vinegar snd saltwater treatment has made a difference though.That can happen occasionally. I found this when I had minor gum infections. These infections clear themselves up on their own and you generally don't notice them. But the agitation of the pick can cause you to notice them.
I use corsodyl when this happens which helps a lot. I strongly recommend any motorhomer carries this with them in their motorhome.
Corsodyl Mouth Wash Mint, 300 ml : Amazon.co.uk: Health & Personal Care
Corsodyl Mouth Wash Mint, 300 ml : Amazon.co.uk: Health & Personal Carewww.amazon.co.uk
If you get toothache it can help keep the pain under control while you find your way to a dentist. I am prone to gum infections around the back of my lower wisdom teeth and this stuff sorts it out pretty quickly.
Since when did false teeth have root canals?????Wimp, I've had several root canals done without anesthetic.
Eucryl smokers toothpaste (powder) knocks back plaque pretty effectively. Used once a week you can keep on top of it.Yes, I like Corsydol too but at present only have Listerine as where I shopped had it on offer, but it is not as good. I have no problems - I don’t think - but just aware that have not seen dentist this year and not likely to. Would normally have descale and clean twice a year. Plaque build-up is more of a problem but I know that the water flosser will not remove this. The vinegar snd saltwater treatment has made a difference though.![]()
I use Corsodyl all the time. Great stuffThat can happen occasionally. I found this when I had minor gum infections. These infections clear themselves up on their own and you generally don't notice them. But the agitation of the pick can cause you to notice them.
There was a guy in a pub I used to frequent who would put his glass eye in his beer when he went to the gents.No need....take ‘em out at night,put ‘em on the side. Then,in the morning,run ‘em under the tap and back in a jiffy.
Oh,and when you’re in the pub and need to go for a pee,drop’em in your beer...........that way no bugger will drink you’re beer while you’re in the bog.![]()
