DBK
Give it a go if you want to try it but remember the typical Ah capacity of a battery is based on much lower rates of current draw than you are proposing, by around a decimal point.Illogical or not, I'm not going to change.
Battery power taken will be:
800w / 12a = 66.6ah. For half an hour / 2 = 33.3 ah. Plus 20% inefficiency 39.96 ah.
Say I add an additional battery increasing the bank from from 220 ah to 330 ah.
If I was taking them all the way down to 50% that's 165 ah usable. 165 ah - 40 ah still leaves me with 125 ah to play with.
If I was taking them only to 33% depletion that's 108.9 ah usable. 108.9 - 40 ah and I'd still have 68.9 ah to play with.
And by slowing it down and not hitting the battery with such as massive draw all at once, that will do less damage?
You can boil a kettle in five minutes on the hob. I suggest that as a solution for hot water in the morning. The first kettle for your cup of tea, the next one for a wash.
Alternatively, fit a gas water heater and only turn it on when you wake up and have a gas detector in addition to the normal CO detector.
