Probably a naive question, most of mine are, but why would this have anything to do with adblue?
Have you sprayed it over the battery?
Is there a leak from where you put the Adblue in?
Are you sure it’s adblue or could it just be water?
Difficult to say from the photos.
I can’t see why it has anything to do with adblue, but I will concede I am thick!
Yup.Apparently due to overspill while filling.The picture is of the door step (near Ad blue filler) with plastic base trim removed. Not the battery box.
Was it an inside filler?Yup.Apparently due to overspill while filling.
AdBlue is far less noxious than the NOx it removes from exhaust fumes. It is classified as non-hazardous. Yes it is corrosive to some metals and a mild irritant as are many household liquids. You just need to take a little care when filling and rinse down if you spill it. People seem to single out AdBlue as dangerous but we all handle far more dangerous substances as part of our daily lives.I'm really not convinced about adblue, I wouldn't entertain buying a vehicle with it. Spraying such a noxious chemical into the air seems crazy to me
When I had a VW adblu was not a problem, now I have a Nissan the owners groups are full of bad stories, with many suggesting an adblu delete. So far I've had no problems and it's still under warranty, but down the line when it's out of warranty, if I have problems I may consider having it deleted.I'm really not convinced about adblue, I wouldn't entertain buying a vehicle with it. Spraying such a noxious chemical into the air seems crazy to me, and it does cause engine issues, try googling adblue problems for your make.
On my Mercedes Hymer the AdBlue under bonnet filler was a pain to reach and avoiding a spill needed great care. On my Fiat Van the filler is under the fuel flap and dead easy to use.Some of the fillers are very poorly positioned, my daughter's Range Rover has the filling point at the back of the engine almost impossible to fill from a 10lt container. My VW had it at the front of the engine, better, but still not easy. My Nissan Navara has a full point on the side of the vehicle, easy to fill without spilling. So far I have not found a local garage with a pump.
I got a Syphon pump and stand the 10lt container on my Wheely bin, it's not quick but no spills. Now I no longer have the VW I will only need it for when my daughter visits and steals my adbluOn my Mercedes Hymer the AdBlue under bonnet filler was a pain to reach and avoiding a spill needed great care. On my Fiat Van the filler is under the fuel flap and dead easy to use.
