Victron IP22 30a with EBL220-4 (5 Viewers)
Jun 24, 2019
414
818
Pershore, Worcestershire, UK
A Class Frankia
I am going to upgrade my charging for my 2x 155Lithiums and install a Victron IP22 30a charger and disable the internal EBL220-4 one by removing the front fuse... I cannot make up my mind to connect straight to the batteries or go through the EBL.. will the EBL cope with 30a from the Victron, would it be a case of just upping the fuse... will i keep the ability to trickle charge the starter battery if i go through the EBL .. finally where do I take the mains connection from .. Thanks
Sep 17, 2017
6,251
11,963
Birmingham, UK
A-Class
I'm half way through doing something similar. I just fitted a 20A for my 280Ah battery as I figured it'd still fully charge overnight.
I went straight to the battery. But that was the easiest connection for me to make. I guess you'd use one of the charging ports on the front of the EBL? I think the solar connector on mine is limited to about 20A, not sure if they're all the same?
At the moment, mine is plugged into a mains 3 pin socket that's very close to the cab seats, so there's a tiny bit of cable exposed. I've bought a mains junction box that I'm going to use to tap into the feed that goes to the EBL... when I get the time.
My trickle charger appears to be wired in through the solar input...? I think (guessing!) the cable has 3 wires. Ground, and positive for the hab and cab battery. So the trickle charger just allows flow when the hab battery level is a high enough voltage above the cab battery? It all appears to work outside the mains charger, so I don't think going to an external charger and removing the fuse stops it working.
