- May 8, 2011
- 4,305
- 56,363
- IH Tio 630 RL
- Since April 1846 but have always camped.
But you are obviously concerned about your battery, so for peace of mind just change it.
Not as many vehicles but I've had plenty, I've also never been advised to change brake fluid either, even though I ask for it to be tested.I've had over 50 vehicles during my life. Some work vans, 13 motorhomes and several cars. I've never changed the brake fluid or been recommended to do so. My garage says it's a good earner but never pushes it's customers to have it done.
The brake fluid theme appears to be a modern day thing. I assume in the past they manufactured quality brake fluid that lasted but today it's crap like a lot of things.
Did the garage explain to you why the brake fluid had failed enough to cause traction control & ABS problems?As I said eairler having had traction control & abs problems on my 3 year old van that had done less than 30,000 miles and a change of brake fluid cured the problems. For a few quid to change the fluid its well worth it.
As for the barrery it's well past its best and if it fails in Spain it will cost you well over twice what a battery will cost here.
Fiat couldn't fund any fault withe the Traction control, ABS played up later.Did the garage explain to you why the brake fluid had failed enough to cause traction control & ABS problems?
Thank you for that. I don't think my traction control is working correctly although the symptoms are different to what you experienced - it is allowing one wheel to spin which it isn't supposed to do.Fiat couldn't fund any fault withe the Traction control, ABS played up later.
I had the brake fluid changed when I had a service at 4 years in May by a local independant as we do a lot of mountains.
It's not put a foot wrong since.
If lithium, the LB is happier not fully charged. Can you switch the solar output from lb to sb when van not in use ( or change the wiring to do so)? This would kill 2 birds with 1 stone (i used this method on my bongo which had a permanent parasite drain on SB and the LB did not) . I currently have votronics controllers that trickle charge SB, and an issolator on the LB Negative.I don't have the solar charging the LB at home as I understand they are happier if not kept fully charged when not being used. Can anyone clarify?
This is an interesting perspective, bake fluid is hydroscopic and will degrade. Just wait till your coming down a mountain pass and have old brake fluid it’s boiling point changes. I took a Brand new Mercedes’ sport out at silverstone the car did not last the day after about 3 outings and 5 laps a go the brake fluid boiled and that was the end of the day for that vehicle as the braking performance of that vehicle was impaired. A VW Golf GT lasted all day but needed a new set of tyres as the ones it had were pretty much worn out. In fact all 5 vehicles had tyre and brake fluid changes along with a change of oil and filter.I've had over 50 vehicles during my life. Some work vans, 13 motorhomes and several cars. I've never changed the brake fluid or been recommended to do so. My garage says it's a good earner but never pushes it's customers to have it done.
"toits", I had a round toit but couldn't be bothered with it.Van brake fluid changed this morning. The reservoir was nice and clean [Van 5.5 years old but had only 8767 miles on the clock] and the original fluid looked like medium coloured pee. The new fluid is more of a light primrose yellow, so I suspect that the old fluid was the original from 2016, rather like the aircon that we had to have regassed in mid July for the first time since the M/Home was built.
We seem to have a low mileage/low maintenance undertaken vehicle. But, on the bright side, we won't have to risk finding out on a descent of the Pyrenees that we should have changed the brake fluid, and we are just about at the stage where everything that should have been changed/recharged/regassed or serviced has now been covered, so we have only to keep it that way ...
I'm too old for the excitement of 'Will it start/will it stop' uncertainty, and I'd rather pay a few quid and survive to see the holiday through toits scheduled end date.
Steve
Laptop dying by instalments with key presses failing perioidically on 'd','e' the right hand conventional bracket above zero, and the zero key [that's why I always use square brackets; they still work, although the opening square bracket is beginning to get a wee bit flaky ...], and the spacebar. The latter has always been quite stiff and requires a thump, rather than any attempt at touch typing. I should replace the laptop, but cannot decide what to buy as a replacement. Probably sensible to wait and see how Windows 11 pans out, and, in the meantime, become a little more careful with pre-post proof reading."toits", I had a round toit but couldn't be bothered with it.
If you and yours are happy that's all that matters.
No overly important; no-one died. And I have some toits at our French hovel that may need attention after a 21 months absence ...
Steve
"T" not working eitherLaptop dying by instalments with key presses failing perioidically on 'd','e' the right hand conventional bracket above zero, and the zero key [that's why I always use square brackets; they still work, although the opening square bracket is beginning to get a wee bit flaky ...], and the spacebar. The latter has always been quite stiff and requires a thump, rather than any attempt at touch typing. I should replace the laptop, but cannot decide what to buy as a replacement. Probably sensible to wait and see how Windows 11 pans out, and, in the meantime, become a little more careful with pre-post proof reading.
Steve
That's the Scots dialect, It's no overly important ... In the English language it signals an error of typography ..."T" not working either
"Not" overly important.
Need to get out more boy, that's only one years mileage in my book.[Van 5.5 years old but had only 8767 miles on the clock]
We have, Lenny. 8767 was the delivery mileage, now sitting at 11469, so 2702 miles since purchase, and we had to cancel the trip to Lincoln because of the diesel shortage, so that's a touch over 700 miles we've missed out on; but we've got the anticipated trip to Spain [COVID Booster + Flu Jags and a couple of minor medical bits to sort out first, just waiting to finalise dates] and this should add 4000 miles, maybe a few more. I reckon that we'll cover around 9000 miles by the first anniversary of buying Brunhilde, comfortably exceeding the previous 5 years' total mileage ...Need to get out more boy, that's only one years mileage in my book.
Brake fluid degrades and as I say you may not know it has until the brakes have to start performing under pressure such as that mountain pass.
Whatever they came withOut of interest what dot were you running in the cars at Silverstone.
