If the battery is not as good as it used to be, tells me you don't have adequate charging to replace what you used, as it is.
Craig solar do a square 200w panel that could fit the space you got. Measure up and check it out.
Any lithium battery you chose, make sure it has at-least 120A bms. This is minimum for your use.
