Just unplugged the EHU and this is reading from box
I am currently on a campsite on the Ile de Re,but last night we were on an aire in Cognac. The leisure batteries went down to 11.9 last night with only a couple of LED lights,tv for a few hours and heating for a few hours. With those on,the Sargent EC450 box said I was using nearly 7amps,but now I am on EHU and with every light on,tv and heating on electric it says I am only using 1.1 amps!
So how can I find out what’s drawing power from the leisure batteries that doesn’t draw when I am on EHU?
The Sargent system is set to deliver 10 amps charge and up to ten amps to the 12v system components when on hook up
It is also set to top out at 13.8 volts which means the system never goes in to bulk charge mode ( a bone of contention as far as I am concerned )
Looking at the figures suggests the Sargent is working correctly
Volts went down to 11.9 last night, but when was the last time you was on hook ?
The batteries are charging with the engine running, but to fully charge a couple of 100 Ah batteries you would have to be driving for 10 or 12 hours
How long had you been driving that day ?
How many solar panels have you got ? Was it a bright sunny day that day ?
at a guess I would say your twin 90ah batteries would last at LEAST 8hrs from fully charged. with the load the sargent is suggested is being drawn, if you are saying, even with solar, they went flat in a couple of hours, then there appears at this stage to be something wrong with them as the charging seems to be fine.
I don't care whether they were only bought in September last year..
Yes fridge is still on doh0.8amps doing nothing... something is still on..
Fridge?
That's not a good sign..
Can you not switch the fridge over to gas?
Is it a compressor fridge?
As that 0.8 amps could be when it's just "idling" (i.e fridge thinks it's cold enough so doesn't power up).. When the compressor kicks in though... That'll be where your battery power is going (most likely) if it is running and is a compressor type..
At the beginning Jo said he was using LED lights, so not sure where the flouros came in..Fluorescents are power hungry for what they are.
They run on 230vac so have small, primative inverters inbuilt.
Inverters eat power, even little ones, for what they give back.
Best option with those is remove the guts and fit LED strips inside the casing.
My old RV had nine of them, all twin tube jobs.
In total, all running, almost 24amps.
I had 440ah of battery power but still swapped for LEDs.
They are power hungry buggers as you say, that is at least halfed his amp draw by not using the flouros but using the LED's instead..
I gotta go to bed.. peace out. try again tomorrow..
Go through every item in the van and jot down the BATT AMPS reading for each.
We'll find it eventually but definitely need to find what's using nearly an amp with everything off..
10 watts.. sounds like a bulb of some sort. perhaps its the power consumption of the actual sargent unit!!!
You’ve not got a light in the garage/wardrobe that’s on...? Cab radio, something plugged in charging ..... outside light.. reversing camera ...
‘’climb in the fridge and see if the light stays on when the door is shut...?
just trying to jog your memory....??
Old wives tail why does everyone blame Truma heaters. When on full blast they draw about 5.5 amps but that is only for a short time once the van is up to temp it drops to less than 1 amp with a CP Plus controller or a little be more with the classic controller.You forgot the power eater...... The heating fan.
Usually Sargent unit will draw .2 to .5 amps depending on which model it isYes the Sargent box must use some,and the solar controller?
I turned every thing off at the reading was this
I have four fluorescent bulbs I turned on and the amps went to this with just them on
that seems alot for just those on?
But they've always used almost 4amps every hour they're on.But I have always had these lights but never had the batteries drain like they are now.
