- Feb 5, 2024
- 468
- 673
- Etrusco CV540 DB
- On and off for about 30 years
That is interesting.The main problems with using a VPN is that they are very easy to detect and so block.
1) Any IP address that has a large number of connections to the streaming platform will get blocked. This is a fundamental problem with public commercial VPN services that have large numbers of customers and only a limited number of exit points.
The best way around this is to have a personal VPN from your van back to your own house. This will then look to the streaming service like an ordinary household using their service. I use my Pepwave router in the van which has a “Speed Fusion” feature that makes this easy. The software for the part that runs on a computer in your house is free. Speed fusion is highly optimised for streaming data it can also add several connections together to gain bandwidth which is also useful. I never get blocked by streaming services when using it on my laptop in the van (see next point).
I have also used Tailscale which is easy to set up on most devices. It is not so well optimised for streaming but is free, it is really useful.
I used to work in IT, but though I'm not a network nerd, that sounds like something I could do. I have a GL-MT3000 (Beryl AX) Router in the van and have found that it can run both vpn clients and servers, and also has a DDNS service. I was looking into using this to connect to the van's systems remotely but was stymied by the fact that both Starlink, which I mainly use, and the mobile networks use a form of internal address translation which prevents the use of a DDNS.
If I bought another Beryl router (only £62 Black Friday price on Amazon) to use on our Virgin broadband at home (Virgin router is already used in modem mode) I assume I would have to run a DDNS on this in order to overcome the non-static addresses used by Virgin? If I were to set that up do you think the VPN server in the Beryl router then be suitable to act as my own home based VPN service?
