Urgent help please. (1 Viewer)
Tom A
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
Our neighbours have just arrived on site and they've no 12 volt power to their 2013 Chauson Flash 10.
240 volt is working. Is there a switch to turn charger on and if so where is it located?
Jul 25, 2017
414
1,124
Rugby
Elddis Autoquest 185
Since2012
Yes on ours top right button to switch on panel then bottom left button to switch 12v supply for lights etc
Tom A
Tom A
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
Pressed power on but nothing. I think leisure batteries are flat/knackered but wondered if 12v could be powered off charger?
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
Do you have a multi meter?
May 29, 2013
2,625
19,475
Tyneside
Chausson best of Flash 10
Several years now
From memory (could be wrong) there may be an overload reset button on the charger. Perhaps that needs pressing ?
But the leisure battery should have been charged by the alternator while driving, so suspect it is more than a charging problem.
Feb 9, 2008
4,097
5,931
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Is the charger switched on at the distribution box, we have accidentally knocked ours off before.
May 29, 2013
2,625
19,475
Tyneside
Several years now
Are there any LEDS alight on the panel if you press the top right power switch ? Such as pressing the water tank level button ?
Apr 22, 2018
6,843
12,619
Herts.
Adria Coral lowline
Check the 240v fuse box and check if the breaker is on. Then check if 240v at charger
Wabs
1,022
3,666
Dartford
Bessacarr E572
Always learning.
I’d start with testing the leisure batts,( if you have a torch), start with the obvious and work back,, don’t know anything about their specific van sorry (y)
May 29, 2013
2,625
19,475
Tyneside
Several years now
Can't find the charger.
It's in the storage box under the side seat directly behind the passenger seat. From memory its a black plastic box, it may also have an indicator light on it. Or not.
