Lenny HB
- Oct 18, 2007
- 59,712
- 187,773
- Carthago Compactline
Probably get a 50 watt either side of front rooflight as well.
We have 250W of solar, but only use the inverter for 10 minutes for wife's hairdryer every 3 days or so. No B2B but our Hymer charging system is better than many others. All other heating and all cooking is done by gas. Pre covid we tended to go early spring and early autumn to Spain, Portugal or Italy and could survive OK off grid with the solar we have and using a couple of AGM batteries.Thank you for your response. We do tend to head off for warmer climes from November onwards. Not very good in Welsh climate. Doesn’t stop raining in Pembrokeshire. Still reviewing usage etc and plying the boss with gin and tonics so she will sign off the agreement
Hi Peterc10,We have 250W of solar, but only use the inverter for 10 minutes for wife's hairdryer every 3 days or so. No B2B but our Hymer charging system is better than many others. All other heating and all cooking is done by gas. Pre covid we tended to go early spring and early autumn to Spain, Portugal or Italy and could survive OK off grid with the solar we have and using a couple of AGM batteries.
Another thing to think about is a second toilet cassette. Bought one early last year but no used yet. Hope that will give us another 2 or 3 days before needing to find somewhere to empty. Room in the garage to store it in a sealed box. Cheapest way is to buy the Thetford fresh up kit for your model number on line.
Not wrong Lenny. Bloody shame as I don’t use the satellite. Only got one radioLooking at your photo a sat dish and 2 TV aerials a bit OTT![]()
It is best if all panels are identical size and make. Otherwise, the mismatches can cause large inefficiencies as panels run at the wrong voltage (if wired in parallel) or wrong current (if wired in series). If you do have mismatches, best to wire in parallel (as voltages will be better matched on different sized panels than the current rating) and forego the ability to run in low winter light that is the advantage of series connection.Id imagine a 200 or 300 ish in the large space and a slime 100 in the small
Providing the panels are of the same type i.e. 12v ones with an open circuit output of 22v it is fine to connect them in parallel.It is best if all panels are identical size and make. Otherwise, the mismatches can cause large inefficiencies as panels run at the wrong voltage (if wired in parallel) or wrong current (if wired in series). If you do have mismatches, best to wire in parallel (as voltages will be better matched on different sized panels than the current rating) and forego the ability to run in low winter light that is the advantage of series connection.
Although personally, I think that roof is pretty rammed already and you're going to struggle to get much up there. Too many rooflights and antennae! I think your best would be 5 identical 60W panels into the little gaps wired in series, although that would go over the 100V of the cheaper MPPTs. It would provide the best shoulder season/winter current, though. In summer, you've always got far more than you need, so you don't even need to consider that! Without measurements, though, it is hard to tell what would fit where.
See a second aerial fitted on Hymers a lot on Brit dealer supplied ones they don't understand their product and the customer ends up paying for a second aerial. Even before Hymer started fitting the whip aerial they had one built into the overcab.Not wrong Lenny. Bloody shame as I don’t use the satellite. Only got one radio
already on van when I purchased it
I guess I fall into the new generation using 4/5G.
I am glad I put up thread as I thought I was up to speed off grinding but everyday is a school day
PS mean off griding not off grinding![]()
Different panels will still have different voltages even for nominal "12V" panels. However, the difference isn't enough to stop them working, there will just be slightly less MPPT potential. Certainly, for mismatched panels, parallel is the way to go.Providing the panels are of the same type i.e. 12v ones with an open circuit output of 22v it is fine to connect them in parallel.
Connecting 5 panels in series is not a good idea only needs one to be shade and you will lose the output frome all of them. For Motorhome use always best to connect in parallel.
You might be right but i will have to have a good think about removing the satellite. Glad you like the Victron set up.Could you not remove the satellite and seal the opening? Then cover with more panels?
If you aren’t going to use it, that’s a lot of weight and space taken up.
Solar in the darker months isn’t great, you need every last bit you can get. Looks like a great setup, just sorted mine out and I love the Victron kit.
Sorry, slightly of topic, i laughed when i seen this post. My youngest son( he,s 30) gave me into trouble for using the devil emoji in a text to him the other day , why because the youth of today use it to relay the fact they feel a little HornyAgain, thank you for your input and now you have got me thinking. Need to off load the wife and I will be quids in![]()
Ha ha.....ouch. Better be careful with that emoji as it’s my favourite.Sorry, slightly of topic, i laughed when i seen this post. My youngest son( he,s 30) gave me into trouble for using the devil emoji in a text to him the other day , why because the youth of today use it to relay the fact they feel a little Horny.
Just to add put as much solar on the roof as you can fit, great setup.
Cheers Cris
In addition I would have thought that you could fit 2 x100w panels either side of the front skylight but you will need to fit a wind deflector alone the front for aesthetics and wind noise.Id imagine a 200 or 300 ish in the large space and a slime 100 in the small
Hi,
I have renewed my van to a Hymer B704PL.
I normally camp off grid (FLT) New van has no added extras.
I have booked to have the following added:
Solar 175W Victron MPPT Regulator
Sterling B2B 60A
Victron Multiplus Inverter/Charger
Victron Multiplus Digital Multi Control
Victron Smartshunt Battery Monitor
2 x 100a Lithium Batteries
I would appreciate it if one of the off grid pros on here could review this setup and give me any suitable advice. No wise cracks please.
Many thanks
I installed a diesel heater. I travel offgrid a lot in winter and find big prob is amount of gas used. 10 ltrs oil last a wk against a bottle of gas 4 days. With this setup a bottle lasts at least 4 wks cooking hot water and fridge. This saves me taking multi bottles travelling in europe.Hi,
Sterling B2B 60A
Many thanks
That tracker is beautiful. Can you tell me if is a off the shelf design, and could I get one?View attachment 474190Of course if roof space is an issue, fit an automatic self tracking solar panel.
100w, and averages FIVE time more efficient when tracking the Sun then when it’s parked and just like a conventional flat’ panel.
Changes direction every hour to chase the Sun, and uses GPS to check correct elevation every morning
Great thread and lots of really useful stuff here. Nice problem to have Toady
On the subject of coffee machines, not sure what you have, but we decided our Gaggia machine was a bit much to take in our van, so I bought this:
Amazon product ASIN B07R55GT28If you boil water on the hob, this can produce an espresso in under 10s from Nespresso or L'or capsules. We've tried many different capsules now and it makes an espresso every bit as good as our £500 Gaggia at home. Charges from a cigarette lighter. Single charge gives you 100+ cups (using hot water).
Raul mentioned a company called Craig Solar to me on a thread I have on the go about upgrading my electrics...
I was stunned at the prices, and that for the size, their panels seem more efficient than others of the same size.![]()
12v charging conundrum
You can get semi flexible or flexible solar panels. I believe that the ones that 'stick on' are not quite as efficient as the panel that has a gap underneath as the gap allows for cooling but there are many Boats and MoHo's out there with these. Having read up on them, it's not just that they...www.motorhomefun.co.uk
Raul, you mentioned Panasonic HiT panels above in post #46. I guess they're more expensive than the Craig Solar, but do you know of a good supplier?![]()
2 years ago when i was in Portugal a dutch lady had her sat dish (dish part only)removed and a solar panel fitted onto the the working parts,so the panel could change direction. A couple of guys staying on the aire done it . It looked good and worked,don,t know how save when driving but a cheap version of yours.View attachment 474190Of course if roof space is an issue, fit an automatic self tracking solar panel.
Have you tried a stove top Mocha pot. Italians love coffee and nearly every Italian home has a mocha pot.Great thread and lots of really useful stuff here. Nice problem to have Toady
